What is that squeak - Team Camaro Tech
post #1 of 2 (permalink) Old May 7th, 06, 05:12 PM Thread Starter
What is that squeak
I have a new squeak in my steering column, has this happenned to anyone else. I tried a small amount of lubricant, it still squeaks when I turn the wheel. It sounds like metal to metal, any suggestions will be appreciated. I have a '68 RS/SS Convertible without tilt wheel. I changed the nsteering wheel a few weeks ago, but this noise just started.
Texas Bulldog is offline
post #2 of 2 (permalink) Old May 7th, 06, 11:45 PM
Re: What is that squeak
Did you install an aftermarket steering wheel such as a Grant steering wheel with the adapter kit with a new cover/ collar? The covers sometimes rub on the steering column creating that grinding sound. Try shimming it out with a flat washer and see if that helps. There should be a big enough gap between the bottom of the cover and the top of the column. I have a feeling that is your problem.
Camaro buds until the end!!!
Camaro Dave is offline
Squeak under body Chris Lowe Camaro Tech 2 Jan 6th, 06 01:42 PM
gas tank anti squeak? jus4funn68 Restoration Corner 2 Feb 14th, 05 11:18 AM
Front end squeak BamaBoy Brakes, Suspension & Steering 2 Apr 7th, 04 02:16 PM
squeak when shift josh schaad Engine 5 Sep 6th, 01 06:41 AM
