heat - Team Camaro Tech
post #1 of 5 (permalink) Old May 9th, 06, 08:08 AM Thread Starter
heat
hello I am working on a 1968 camaro just overhauld the 327 board 30 over double hump heads with 194 vavles with a cranecam .467/.494 not real big also car has AC my problem is car runs at 195 temp that is; at stop but with AC on car runs at 230 also had radiator cleaned new waterpump has a 195 thermostat the clutchfan seems to be fine.ANY HELP WOULD SO GREATFULL. THANKS
fatback is offline
post #2 of 5 (permalink) Old May 9th, 06, 09:04 AM
Steven
Re: heat
I would go back to a 180* thermostat just to allow the coolant to begin circulating and disappating heat sooner... Also, are you running a shroud ... If not, it would help because it focuses the air flow through radiator better. The number of cores on your radiator may be a problem because of less cooling surface on smaller radiators. Also, check your timing.. If you timing is somewhat retarded, it can make the car run hotter... BTW, do you have a fast idle solenoid to bump the idle when AC is on ?
sdtsdt is offline
post #3 of 5 (permalink) Old May 9th, 06, 02:07 PM Thread Starter
Re: heat
the car does have a shroud.but it does not have a fast idle solenoid can i install one on the carb it is a holley 600 cfm thank you for the help also can you tell me what a ambient switch is and if i can test it as far as i know it is located on the rh side of the evaporator box? THANKS
fatback is offline
post #4 of 5 (permalink) Old May 10th, 06, 06:53 AM
Steven
Re: heat
as far as the fast idle is concerned, check the holley catalog ...they do offer a solenoid and a bracket ...
I don't speak AC specifically, but I think that an ambient switch will not allow compressor to run if ambient temparture is too cold
Has anyone check your condensor? Make sure that it is clean and that you are getting good air flow through it ...
Once again, make sure timing is not retarded and make sure carb is not too lean .... And I would still ditch the 195 thermostat in favor of 180. The thermostat doesn't enforce a max upper temperature, but it does determine how soon coolant circulation begin. It may slow the temperature climb enough that you don't climb as high at stop signs...
sdtsdt is offline
post #5 of 5 (permalink) Old May 10th, 06, 08:02 AM
click's Avatar
Re: heat
I run a 180 Tstat and my temp guage sits around 180 - 190 at idle and a little less at highway speeds. I jerry rigged an idle stop solenoid onto my Qjet as I cant find the bracket but Holley does make one Ive seen in catalogs for their carb. or you can jerry rig your own. I got my solenoid at salavage yard off 80's vintage chev. carb and bolted it near the throttle area and then adjusted the 'throw' on the adjust. stem. Works like a champ kicks my idle up about 200 rpm at stop signs.
click is offline
Heat treating 101??? GMJim Camaro Tech 12 Mar 8th, 05 03:47 PM
Header help: clutch linkage and heat soak laabs Engine 7 Jun 27th, 04 04:10 PM
Heat Riser Indy Z11 Engine 5 Aug 23rd, 02 04:55 PM
Heat riser/crossover through the intake Sleepy-69 Engine 3 Nov 19th, 01 01:24 PM
HEAT SOAK? 67drake Tech 2000 11 Jun 2nd, 00 07:16 PM
