backfire - Team Camaro Tech
post #1 of 2 (permalink) Old May 11th, 06, 05:08 PM Thread Starter
Rex
backfire
My 69 is acting funny lately. It has started to backfire through the exhaust. I have a 383. Initial timing is at 6 degrees with the vacuum advance unhooked I am at 25..I hook up the vacuum advance it goes to 45!! This has just started. I also seem to have a real weak spark (Complete msd ignition. The coil is a blaster 2). Also..the car seems to be shocking me when I get out?? I am thinking a bad ground for the shocking me and maybe a bad coil starting to develop, but why would the vacuum advance change so much? The backfire out of the exhaust? What could cause this? The car has also giving me trouble before not wanting to start...usually at a inopertune time and there would be no spark, but It would be ok after awhile. Do I need to buy a new coil and change the advance springs inside my distributor?
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
post #2 of 2 (permalink) Old May 13th, 06, 01:45 PM
Kevin
SixtyAte's Avatar
Re: backfire
Hook up a vac gauge to the port you have the line connected to or see if its constant from that port. If it is, its hooked to the wrong port on the carb, so try another port. Put a ground strap from the battery to the frnder bolt and one from the engine to a motor mount bolt or in that area. Clean all ground connections. Without a good ground, the ignition coil isn't going to get full time current needed to give 6-8 volts. Intermittent ground will cause your many problems.
Kev
SixtyAte is offline
Single cylinder intake backfire (popping) Michigan67Vert Engine 9 Dec 17th, 05 11:00 PM
Cold Start Backfire - Supercharged awsm502 Troubleshooting 2 Sep 20th, 05 03:05 PM
A general question about a tailpipe backfire denverRS/SS Engine 1 Aug 26th, 05 01:08 PM
Backfire... BOOM... really loud one ?? click Troubleshooting 7 Jun 18th, 05 02:41 PM
Ignition backfire problems. IrelandCamaro Troubleshooting 0 Jun 2nd, 05 03:37 PM
