What Happened? - Team Camaro Tech
post #1 of 6 (permalink) Old May 21st, 06, 07:42 AM Thread Starter
Thumbs down What Happened?
I took my car (91 Camaro RS) in a week ago to have a defective (purchased 2 months ago) starter replaced. When I left, and got on my way to work, I noticed my power door locks wouldn't work...and since then, I've also noticed the horn, trunk popper, headlights and parking lights aren't working. What could have happened when they were replacing the starter?
I am taking it back in on Wednesday to have them look at it....I'd like to have an idea of the problem before I go.
ChevyGirl is offline
post #2 of 6 (permalink) Old May 21st, 06, 08:06 AM
Re: What Happened?
I was going to suggest a fuse, but if the healights are out it soundls like they forgot to connect a wire somewhere. It is kind of strange that the locks aren't working, but the dash and radio are. (I'm assuming you use the radio and would notice if the gauges were dead.)
I'm guessing a ground wire was disconnected, since most of the non-functioning items get power from the fusebox (headlights have a circuit breaker somewhere), but you don't list other things as being out that also get power from the fusebox.
GetMore is offline
post #3 of 6 (permalink) Old May 21st, 06, 08:20 AM Thread Starter
Re: What Happened?
Yeah....my radio still works, and my turn signals & brake lights too. The gauges still work. I'm assuming it's something they did or didn't do....too much of a coincidence. My X husband checked the fuses, and none were blown. I'm a little ticked off about it...I just had $1,700 worth of work done on it....and it's like new now....except for this little problem!
post #4 of 6 (permalink) Old May 21st, 06, 09:31 AM
Re: What Happened?
Headlights and parking lights are not fed thru any fuses. There is a fusable link between the battery and the ignition switch. Theres a red and black wire that comes off the battery positive terminal and goes to a terminal block. There are a couple of other wires that also come off the battery that go to terminal blocks inside a plastic box. The one you want has a red and black wire in, and then a fusable link and a red wire to the interior of the car.
Door locks come off a 20 amp fuse in the fuse panel labeled ACC and the 25 amp fues labeled WPR. The wpr circuit feeds the door lock relay motor.
http://www.autozone.com/servlet/UiBr...3d801eef19.jsp
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #5 of 6 (permalink) Old May 21st, 06, 10:06 AM
Re: What Happened?
I think Mark is right.....check the fusible link towards the battery. They might of arced something when they disconnected the battery to work on the starter. All those accessories are always "Hot" since you do not need to have the ignition on for them to work. The fusible link is what ties them together.
Camaro buds until the end!!!
Camaro Dave is offline
post #6 of 6 (permalink) Old May 21st, 06, 04:40 PM Thread Starter
Re: What Happened?
I hope that's it....the problem is, when I called to tell them what was going on....the manager acted like there was no way there could be these problems from changing the starter! This is a very reputable chain shop....but now I don't trust them. This is why I wanted the info...so I'll have a little knowledge, and won't get screwed over. Thanks guys....I'll let you know what happens!
What Happened? JIML82 Camaro Tech 1 Jan 21st, 06 06:12 AM
Buck, what happened? MrDanB Bench Racing 10 Nov 16th, 05 09:58 AM
remember this 1967 camaro ? wonder what happened LOL!!! RS3SDL2MG Bench Racing 7 Oct 29th, 05 04:49 PM
What happened to Courtney? Infamous Bench Racing 18 Jul 23rd, 05 01:54 PM
what happened to the L-88's? shiner16 Tech 2000 19 May 5th, 01 02:04 PM
