69 alignment problem - Team Camaro Tech
post #1 of 2 (permalink) Old May 21st, 06, 01:13 PM Thread Starter
I have a 69 camaro that has a major alignment problem. The bottom of the front wheels bow in causing the tie rod arms to rub up against the tires. My fear was that it was a bent frame, but I took it to an local alignment shop and he said he was able to get it into alignment but a soon as he would take it for a spin in would fall back out of alignment. He said the bushing were pretty worn out but that it would cause it to do that. He also looked under the car and noticed nothing bent or unusual that would caused the problem. Im someone has maybe been through something similar or someone who knows more could shed some light on what the problem could possible be.
smattix is offline
post #2 of 2 (permalink) Old May 21st, 06, 06:43 PM
JohnZ's Avatar
Re: 69 alignment problem
If the tie rod ends are touching the tires, it has the wrong wheels on it; the relationship between the tie rod ends and the spindles is fixed, and isn't affected in any way by alignment. If it lost the alignment settings when driven, the upper and lower control arm bushings are probably shot and need to be replaced.
JohnZ
CRG
JohnZ is offline
Gonna fix a 69 dreamweaver Bench Racing 31 Jul 23rd, 06 07:18 PM
Q-Jet Problem LukeWarm Troubleshooting 7 Apr 22nd, 06 10:43 AM
Weird Vibration Problem Cameron Brakes, Suspension & Steering 11 Apr 19th, 06 07:18 AM
69 Rear Side Window Fuzzy Problem, Help! Buildinga55 Body Shop 3 Mar 7th, 06 02:57 PM
weird starting problem matth Electrical & Wiring 2 Mar 10th, 02 05:35 PM
