89 iroc quits - Team Camaro Tech
post #1 of 1 (permalink) Old May 22nd, 06, 01:03 PM Thread Starter
89 iroc quits
I got an 89 iroc efi with a new cap&rotor, coil, wires, plugs, ignition module, and swapping back and forth an MSD-6AL.
The trouble is, it just up and quits on me anywhere from 1-30 minutes after I start it, most of the time it restarts, sometimes it doesn't. (Like now)
I'm pretty sure its getting fuel by the smell and it generates no engine codes
I dont get it.
Sometimes the idle roughens out before it dies, other times it goes off like the car was turned off.
When it dies there's a buzzing noise coming from the plenum area that sounds like a bee trapped under a sheet of paper, its about 1.5 seconds and then a 2 second pause and it stops after I turn the ignition off.
This car has left me stranded in several intersections and on the side of many a road trying to figure this out
Please help
Serial is offline
I got a 88 iroc couple questions camaro88tx Transmission & Driveline 2 Mar 28th, 05 10:45 PM
Power Steering Pump mods for Iroc Box CamFrk68 Brakes, Suspension & Steering 4 Aug 31st, 02 03:41 PM
Reasons to keep my Iroc? Timmys88Z Tech 2002 8 Jan 28th, 02 07:32 PM
Is and IROC box the same as base Camaro? MrKwik Brakes, Suspension & Steering 13 Dec 5th, 01 10:03 AM
Gen 3 Iroc Blind Freddie Tag Team 2 Jan 30th, 01 05:53 AM
