Flat Spot In All 4 Gears - Team Camaro Tech
post #1 of 5 (permalink) Old May 23rd, 06, 11:16 AM Thread Starter
I just started getting a flat spot (1/4 - 1/2 SECOND) hesitation when I nail the pedal to the floor. Happens in all gears even @ 50mph in 4th.
Everthing in this car is new with approx 1500 miles on it.
Has Holley 700cfmDP and 4:10 posi rear and MSD6A.
Schoon
Schoon
SCHOON is offline
post #2 of 5 (permalink) Old May 23rd, 06, 12:22 PM
Re: Flat Spot In All 4 Gears
Now that the weather is changing, time to retune your carb ?
Only other thing i can think of is if they changed the gas in your area, seeing more and more "blends" (E85 stuff).
68 Camaro~LSx ~all motor
post #3 of 5 (permalink) Old May 23rd, 06, 12:41 PM
Steps
Careful when diagonsing "hesitation"
Often it is not hesitation but, normal accelleration then secondaries kick in and takes off.
A well set up carb u will NEVER feel the transition to secondaries (as is commonly believed)...the transition is smooth.
Also check out saimilar threads re setting up pump gap.
Steptoe is offline
post #4 of 5 (permalink) Old May 23rd, 06, 06:42 PM Thread Starter
The carb is a Holley 700cfm Double pumper so I shouldn'd feel the secondaries kick in. Could this be from crapy gas.
Schoon
SCHOON is offline
post #5 of 5 (permalink) Old May 24th, 06, 08:40 PM
Darrell
check the acc,pump and see if as soon as the throttle is touched the pump starts squirting fuel
Seneca SS is offline
what gears to use... rich1 Transmission & Driveline 2 Apr 1st, 06 06:42 PM
quadrajet flat spot z-37 Troubleshooting 6 Nov 20th, 05 06:44 AM
Preventing Flat Cams? GOSFAST Performance 23 Sep 10th, 05 06:44 AM
flat spot, popping sounds and bad idle JL Engine 11 Jun 8th, 04 12:46 AM
rocker help please KCBlkPanther Body Shop 3 Feb 16th, 04 03:10 AM
