I broke a pot metal stud--any way to still use it? - Team Camaro Tech
post #1 of 5 (permalink) Old May 30th, 06, 04:12 AM Thread Starter
Brent
Brentmc's Avatar
All,
I removed the chrome SS inserts from my hood. In doing so, I broke two of the mounting studs. One of the inserts now sits too high in the back because it is not tightened down.
I still have about 1/3 of a stud left. Is there any way to still use this stud? Maybe another type of fastener, repairing it, or?
1968 RS/SS Lemans Blue
Brentmc is offline
post #2 of 5 (permalink) Old May 30th, 06, 04:46 AM
Bill
Re: I broke a pot metal stud--any way to still use it?
Brent,
How thick is the insert ? Any chance you could drill and tap a hole in it and use a small stud to hold it in place ?
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 5 (permalink) Old May 30th, 06, 04:49 AM Thread Starter
Brent
Brentmc's Avatar
It might be thick enough for that--I will check it tonight. That could work well if I have enough material to drill.
If not, is there something anyone can think of that would allow me to use the remaining stud and tighten it down?
Brentmc is offline
post #4 of 5 (permalink) Old May 30th, 06, 01:30 PM
Kevin
SixtyAte's Avatar
>>>>f not, is there something anyone can think of that would allow me to use the remaining stud and tighten it down?<<<<
If you can see it protruding the inner hood, maybe a speed nut ( molding nut) can grab it enough to hold it down.
Kev
SixtyAte is offline
post #5 of 5 (permalink) Old May 31st, 06, 06:48 AM
I've never used it on pot metal, but it might be worth it to try some JB Weld. If you don't have the piece that broke off the stud (i.e. joining the two broken pieces with the JB Weld), just use the JB Weld to "build-up" a new stud. After it drys, simply file it down to the size needed.
cowboybob is offline
"Basics of Basics" Metal finishing trim and mouldings. MARTINSR Body Shop 0 May 21st, 05 07:10 PM
"Basics of Basics" Stainless trim repair / metal finishing MARTINSR Body Shop 1 Oct 5th, 04 11:27 AM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 01:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 01:57 PM
Plug Welding Balboni Body Shop 3 Jan 4th, 03 01:35 PM
