help with CODES - Team Camaro Tech
post #1 of 3 (permalink) Old May 30th, 06, 02:09 PM Thread Starter
help with CODES
hey guys i just had the guys at autozone read my codes but they were no help at all......it flashed 12 26 12. can anyone help me? its a 93 Z28 and i kno in the book it says sumthin about a P vin number and my 8th vin is a P thanx
crazytrain53 is offline
post #2 of 3 (permalink) Old Jun 5th, 06, 11:03 AM
Re: help with CODES
It should tell you what a code 26 means in the same book. I do not have a 93 code book, but did a search on a code 26 and it came up as a Evap Purge Control Solenoid. Hope this helps.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 3 (permalink) Old Jun 6th, 06, 05:38 PM
Re: help with CODES
I have a 94 and I think it was a code 26, or somewhere around there and I am pretty sure it is because the air pump has been disconected and deactivated. You might check that.
LanceZ28 is offline
Evap emissions purge codes: worst-case scenario? velcrokat Troubleshooting 1 Sep 19th, 06 06:40 PM
spring codes TClovis Brakes, Suspension & Steering 0 Jan 22nd, 06 08:42 PM
Confused on date codes edgruber Tag Team 4 Jun 4th, 05 02:46 AM
What are X codes and which vehicles? Nantooch Body Shop 0 Jul 30th, 04 01:50 PM
GET ECM CODES CHEAP SPEEDLVR Troubleshooting 6 Feb 10th, 01 05:15 PM
