Wiper motor - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 3rd, 06, 03:14 AM Thread Starter
Question Wiper motor
I bought a delayed wiper motor for my 68 camaro from Detroit Speed and after running the wiring and making sure the holes all lined up I found that the linkage arm is about 2 inches short from meeting up with the new motor arm. The wipers are in the parked position. Any ideals about what I'm missing or messing up? I doubled checked the motor and it is labeled for the 68. When I bought the car there was no motor for the wipers. The linkage works manual.
john michael is offline
post #2 of 8 (permalink) Old Jun 3rd, 06, 04:06 PM
Kevin
SixtyAte's Avatar
Re: Wiper motor
Is the motor in the correct position? Is it the proper part for your vehicle? All that I have read is that this install is simple. You may have been sent the wrong part. Try and reach them below..
Detroit Speed and Engineering
3753 Old U.S. 23
Suite #200, Dept SC Web
Brighton, MI 48114
(810) 227-6343
www.detroitspeed.com
Kev
SixtyAte is offline
post #3 of 8 (permalink) Old Jun 3rd, 06, 08:16 PM
Andy
Re: Wiper motor
I installed one on my 67 and all went smooth are you sure the motor is bolted in the right spot as far as the top bolt threaded in to the top from rhe inside of cowl? not sure how it would not work have you ran the motor to make sure it s really in park?
67 R/S convertible Nantucket blue deluxe interior orig.
67 rs-ss coupe 565BB-400turbo streetcar/racer project 1.43 60ft 9.683 140.91
2x67rs/ss is offline
post #4 of 8 (permalink) Old Jun 3rd, 06, 08:48 PM Thread Starter
Re: Wiper motor
Thanks for the suggestions, I'm going to call the company today. The motor only lines up one way with the holes on the firewall. I'm going to pull off the wipers and check that they were put on in the right position. Is there any special way to check? I read in past forums how much fun it is to get the wipers off.
post #5 of 8 (permalink) Old Jun 4th, 06, 09:19 AM
Re: Wiper motor
John, try pulling the transmission linkage for the wiper arms to the motor arm and seeing if it raises your wipers higher than normal on your windshield. You might just have some slack with the linkage. I doubt that the wiper arms are in the wrong position.
Camaro buds until the end!!!
Camaro Dave is offline
post #6 of 8 (permalink) Old Jun 15th, 06, 02:25 AM Thread Starter
Re: Wiper motor
Thanks for all the responses. I pulled the windshield wiper arms and sure enough the arms were put on in the wrong position. I put on the motor, worked fine. I waited till it parked and then put back on the wiper arms.... Now I'm ready for the rain; that the car will never be out in...
post #7 of 8 (permalink) Old Jun 15th, 06, 01:03 PM
Re: Wiper motor
LOL! but just in case you are caught out in the rain......
uk68327 is offline
post #8 of 8 (permalink) Old Jun 23rd, 06, 08:23 AM
Re: Wiper motor
3753 Old U.S. 23
Brighton, MI 48114
(810) 227-6343
Kev
Ummm...... They moved to NC about a year ago.
http://www.detroitspeed.com/Contact%20us/contact_us.htm
toxicz28 is offline
Wiper motor wire connectors Bry68 Electrical & Wiring 1 Apr 4th, 05 03:57 PM
Testing Wiper Motor EkS Electrical & Wiring 3 Mar 28th, 05 07:25 PM
Wiper motor YC69camaro Electrical & Wiring 3 Dec 3rd, 04 02:50 AM
Wiper Motor Replacement maddogskip Electrical & Wiring 10 Aug 16th, 04 05:21 PM
wiper motor shaft ball end? jmanel Tech 2003 4 May 8th, 03 12:47 AM
