oil pressure sender - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 10th, 06, 03:57 PM Thread Starter
Steven
stamatisg1977's Avatar
oil pressure sender
i have autometer guages w/ 100 psi oil guage it reads zero now but i know i have pressure. could the sender be bad?
are they known to not work after a while
thanks
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 3 (permalink) Old Jun 11th, 06, 10:34 PM
Re: oil pressure sender
Try and swap out the gauge with a different one. If it works then you know you have a bad gauge.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 3 (permalink) Old Jun 12th, 06, 03:53 AM
As Dave suggests, if it is a mechanical gauge, having an oil tube to the gauge, replace the gauge with a known good one and compare.
If it is an electrical gauge, either the gauge is not grounded, the gauge is not getting ignition powered fused 12 volts, or the sending unit is not grouded through the threads, maybe has too much teflon tape about the threads?
Another check on the sending unit is to measure resistance engine off and engine on, from the terminal to engine block. Should be noticable difference. The gauge can be checked be checked out independently on the battery and ground. If a two post gauge, battery on one post ground on the other and needle should swing to full scale. If a three post gauge, battery and ground to their repsective posts, then momentarily touch ground the the sending unit termnial and meter should deflect to full scale.
Funny but true oil change differences men/women b-boy Bench Racing 7 Jul 11th, 06 12:23 AM
Oil Change MRCOOL_RSSS350 Bench Racing 1 Apr 16th, 06 06:48 PM
AutoMeter oil pressure sender ROBS6T8 Electrical & Wiring 3 Jun 2nd, 05 08:40 PM
Oil pressure sender location 69rag327 Engine 5 Apr 20th, 05 10:47 AM
