MSD distributor install. Do I have to adjust the rotor? Is it possible? - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 10th, 06, 05:10 PM Thread Starter
Question MSD distributor install. Do I have to adjust the rotor? Is it possible?
Ok, so Im giving life to my 94 Z28 I found on Ebay for 1100 dollars. I had the engine rebuilt along with the trans, and am putting all the pieces back together. On my LT1 the Distributor is driven by a shaft that has a flat spot on it. Inside the distributor the rotor is indexed as well so there can be no adjustment there either. However theres an allen bolt beyond the rotor that looks like it could be pulled loose maybe adjusting the rotor location. BUT, the directions say nothing about doing that. I really dont want to loosen that and screw something up. Ive called MSD and they said to get the #1 cyl in TDC position on the compression stroke-done-and make sure the rotor is lined up with the terminal on the cap that says #1. Well thats just great. On the dist. cap four terminals are packed together on each side, and inside the cap eight terminals are nicely spaced in a circle. Besides not knowing what terminal is #1 on the inside, when, or if I need to adjust the rotor how the hell should I do that?
johnson10 is offline
post #2 of 2 (permalink) Old Jun 10th, 06, 10:30 PM
Steps
Re: MSD distributor install. Do I have to adjust the rotor? Is it possible?
Use a multi meter or test light between terminals to find which is which
Most dizzy main housings have a mark on the base where #1 lines up...this normally faces directly to the front of the engine.
Steptoe is offline
Lifter adjustment, warm or cold? gotsnappy Engine 32 Apr 20th, 06 06:41 PM
MSD system shear hell plezzzzzzzz help god bless 67camaro_sportcoupe_evan Engine 23 Sep 18th, 05 10:54 AM
MSD 6AL Ignition wiring problem Smokey Electrical & Wiring 6 May 2nd, 05 06:43 PM
Crane HI-6 vs MSD 6AL or other?? Spames Performance 13 Apr 21st, 03 11:24 AM
MSD 6AL ingnition box. Add a fuse ! Marc Electrical & Wiring 1 Oct 13th, 02 07:23 AM
