Need Help First time seeing this - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 13th, 06, 10:51 AM Thread Starter
I have a 1971 SS Camaro with a blown 454, block is a 1973 4 bolt. This is the problem, Saturday I took the car out for a drive and the oil filter gasket failed and dumped 5 quarts of 8 on the ground before I noticed it. Luckily the engine wasn't warm yet and I was only a block from the house. I changed the filter and added oil, started the engine, same thing happened. I put a hp 2002 K & N performance filter and the same thing happened again. The oil by-pass valve in the filter adapter has been plugged for odvious reasons. Engine is using a Kellam High volume oil pump, oil pressure at gasket failure was 70 psi. Runs at 45-50 when warm. I looked at the oil adapter and it appears to be for a older canister style, does this engine need a oil filter conversion kit to work with modern oil filters, it appears that the filter doesn't seat completely to the current adapter. Engine has dual moroso crank case breathers and only blows the gasket under throttle. Any assistance is greatly appreciated.
vader2 is offline
post #2 of 2 (permalink) Old Jun 13th, 06, 11:05 AM
Re: Need Help First time seeing this
isn't this an exact duplicate of a post a couple days ago?
One that did not by any means go unanserwed if I recall correctly.
Vader, perhaps in the interest of keeping the site tidy, you could delete this and add any new info to your original posting?
Hello...long time Camaro driver..first time here. OPUSONE Bench Racing 7 Mar 20th, 06 05:46 PM
Give back vacation time?????? BonzoHansen Bench Racing 21 Jan 7th, 06 11:14 AM
best new time 406sbc jethro81z28 Performance 6 Nov 19th, 03 01:52 AM
Harbor Freight Chop Saw Scooby Doo Body Shop 10 Dec 22nd, 02 04:48 PM
