89 Camaro IROC 5.0 won't start - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 17th, 06, 03:12 PM Thread Starter
Unhappy 89 Camaro IROC 5.0 won't start
Hi gang,
5.0 Tune Port fuel injection won't start. Distributor was fried. I replaced it, then did the catalytic converter, spark plugs, fuel pump, and starter. Ran okay, but idled rough - needs 3 fuel injectors, 2 are weak, reading in single digits, the last is reading 11 - but the motor doesn't seem to be getting fuel. Fuel pump is working. Pressure regulator? Could the bad injectors have just locked up?
Some advice on where to go next would be great. Thanks in advance.
Jimbosaurus is offline
post #2 of 3 (permalink) Old Jul 1st, 06, 07:43 PM
Re: 89 Camaro IROC 5.0 won't start
I would replace the bad injectors. If you still have the problem I would replace the in-line fuel filter. It should be under the car about middle way's. Good luck, hope you get the problem fixed soon. Todd
fasthotrodtodd is offline
post #3 of 3 (permalink) Old Jul 1st, 06, 08:10 PM
ZZ_430's Avatar
What's the fuel pressure reading?
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
My 2 cents on the new Camaro...gotta say it clill Fifth Generation 77 Oct 24th, 06 06:28 PM
68 camaro won't start!!! jheabs Troubleshooting 4 Feb 19th, 06 07:20 PM
92 Camaro 5.0 TBI - Shutting off Problems Mongo0se Troubleshooting 8 Jan 11th, 06 05:56 PM
68 Camaro refuses to start rodsters Troubleshooting 1 Jun 2nd, 02 12:08 PM
My camaro won't start Broden89rs Tech 2000 5 Sep 27th, 00 02:42 PM
