Oil pressure reading - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 20th, 06, 06:45 AM Thread Starter
I installed a mechanical oil pressure gauge. When I start the engine (327) the pressure only reads about 15-20 psi. After about 3-5 minutes it's up to 40 psi, and then when the engine is warm it's down to about 25-30 psi, as would be expected.
Any idea why it would read so low at start up? Could it be from air in the hose to the gauge? Should I have bled this line when I installed it? I thought it would work the air out, but it's been about 3 months now with no change.
Thanks.
all gave some
MY SON GAVE ALL
68DaveV is offline
post #2 of 7 (permalink) Old Jun 20th, 06, 07:31 AM
Re: Oil pressure reading
The air in the line will not affect the reading. Although air is compressable, it will compress to the same pressure as the oiling system and the gauge will read correctly.
dnult is offline
post #3 of 7 (permalink) Old Jun 20th, 06, 07:45 AM
What size is the gauge line?
onovakind67 is offline
post #4 of 7 (permalink) Old Jun 20th, 06, 11:10 AM Thread Starter
It's an autometer gauge. I believe it's 1/8". I'll have to double check.
all gave some
MY SON GAVE ALL
68DaveV is offline
post #5 of 7 (permalink) Old Jul 1st, 06, 04:19 PM
if your tubing is plastic make sure you didn't over tighten it. you can actually pinch the tubing almost closed and not cut through it. (happened to me!) it acted just like what your describing.hope thats it easy fix. good luck
blainedoe is offline
post #6 of 7 (permalink) Old Jul 3rd, 06, 09:33 AM
madmax87's Avatar
Another alternative is go with the autometer electric sending unit and gauge. No hot oil inside your car or crimped lines like your seeing. Here's a pic of the unit installed.
http://i55.photobucket.com/albums/g1...55/Oilunit.jpg
madmax87 is offline
post #7 of 7 (permalink) Old Jul 3rd, 06, 03:08 PM
Harry
dawg's Avatar
one thing to note here is if you use royal purple or torco synthetic race oils the readings will be lower at start up then climb a bit .
I noticed this after changing oil from torco to mobil 1 synthetic.
there is at least a 10 psi difference between the 2.
434 stroker
US Navy retired
dawg is offline
Oil Change Procedures for Women emperor91108 Bench Racing 9 Apr 8th, 12 10:10 AM
Oil Pressure Reading? Camaro Dave Camaro Tech 3 Jan 7th, 06 05:21 PM
Car wont start - smoke at air intake - No oil pressure wrath_of_con Troubleshooting 3 Oct 17th, 05 08:54 AM
Do I need to bleed the oil pressure gauge oil line? ggkeller Restoration Corner 3 Jun 10th, 05 04:20 PM
Oil pressure sender location 69rag327 Engine 5 Apr 20th, 05 10:47 AM
