Horn Contact Spring? - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 20th, 06, 06:46 AM Thread Starter
I took the horn shroud off of my steering wheel the other day to re-align the horn buttons and I canít remember if the horn contact had a spring under it.
The two wires from the horn buttons run to a small round plug like piece that inserts into the horn contact shaft. Is there supposed to be a spring under that horn contact inside the shaft?
I just canít remember if there was one and it may have popped out when I pulled the shroud off of the wheel.
jrager is offline
post #2 of 4 (permalink) Old Jun 20th, 06, 07:40 AM
parkbrau's Avatar
Re: Horn Contact Spring?
For a 69 ?
Yes there is. That is what keeps the tension on that button so it will make contact with the steering wheel.
parkbrau is offline
post #3 of 4 (permalink) Old Jun 20th, 06, 10:02 AM Thread Starter
Yup it is for a 69.
Now I need to look for the spring. It must of popped out when I pulled the shroud off. Thing is that my top was down so it could have popped out of the car.
Thanks for the info. The search is on.
jrager is offline
post #4 of 4 (permalink) Old Jun 21st, 06, 07:44 AM Thread Starter
Thanks for your help Park. I got lucky and found the spring stuck in my front seat.
jrager is offline
horn contact / cancel cam rodek Interiors 3 May 25th, 06 09:38 AM
Help with '68 Wood Steering Wheel Horn Cap Installation on a Tilt column ggkeller Interiors 2 Jun 29th, 05 05:32 PM
Please post pics of your cars' stance after new leaf springs poloz28 Brakes, Suspension & Steering 29 Mar 11th, 04 08:58 AM
'69 horn contact spring, pin and bushing Gary L Tech 2003 15 Sep 20th, 03 09:03 AM
69 front coil spring install ken69 Brakes, Suspension & Steering 6 Nov 1st, 02 06:42 AM
