Loose drivers side window? - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 23rd, 06, 10:15 AM Thread Starter
Thumbs up Loose drivers side window?
Need some help on tighting up the window? I've got a 72 Z/28 and this loose window is driving me crazy. Any step by step procedures? How do you get the roll up handle off?
Duke
dukeme is offline
post #2 of 3 (permalink) Old Jun 24th, 06, 07:37 PM
Re: Loose drivers side window?
The handle is held on with a wire clip on the shaft. There is a tool to remove the handle that you can usually find at the auto parts store, or you can use a coat hanger wire with the end bent into a small J hook to reach behind the handle and pull the clip off.
It seems that you need to pull the door panel off and investigate why the window is loose, may be a worn roller or loose bolt?
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #3 of 3 (permalink) Old Jun 24th, 06, 07:59 PM
highly recommend you pick up a fisher body service manual for your year, all that kinda stuff is in there, it will help you a lot.
Car leaning - Drivers Side Fatigue Rack Man Brakes, Suspension & Steering 5 Aug 24th, 05 08:19 PM
69 side mirrior loose klingrr Body Shop 4 Aug 16th, 05 12:59 PM
moving alternator to drivers side of 68 shanekennedy Engine 10 Jul 2nd, 05 10:02 PM
I broke my driver's side window when I shut the door with it down. Help mazspeed Interiors 13 Feb 10th, 05 07:44 PM
Driver's side alternator Rookobird Heating & Cooling 5 Mar 7th, 04 03:08 PM
