Carb problem... - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 20th, 06, 06:08 PM Thread Starter
Re: Need Holley carb help fast??????
I have a 650 double pumper, and the accelerator pump freezes in place every time i reinstall and give the accelerator a few pumps, this is the onlything i need to get my baby runnin if anyone has some advice please help
nkfee68 is offline
post #2 of 5 (permalink) Old Jun 20th, 06, 06:53 PM
My thought is that if you had 6" vac with the 650 and 45 pv, now you have a larger carb that will give you less vac signal , thus you have less vac? So an 35 pv would be in order to keep from trying to open too early?? You must have a big cam? Makes sense as you say its too rich now? Hpw about accell pump action,, got any? Can you go back to 650?
TC # 349
zdld17 is offline
post #3 of 5 (permalink) Old Jun 21st, 06, 04:14 AM
Agree with DD, bigger carb, less vacuum signal. Also, need more initial advance, maybe full time vacuum to the vacuum advance, if running one.
Aslo, as Travis suggested, look for a vacuum leak. Look down airhorn and make sure fuel is not dribbling from boosters as engine is running. If it is, lower fuel level. Better to open secondaries than it is to drill primary throttle blades.
Set timing using vacuum gauge, set for max vacuum reading. Unfortunately, it may have too much initial for starter and kick back during a hot start. This is why one uses full time vacuum on advance cannister.
post #4 of 5 (permalink) Old Jun 21st, 06, 05:46 AM
Dean
nkfee
Please start a new thread for your problem, this one is over 4 years old.
Welcome to the team
Dean
'69 355-3.73 Moser-Truetrac-TKO-600-Hotchkis-DSE-QA1 coilovers-Baer brakes-17"Budnik's-Speedtech control arms
SICKT9 is offline
post #5 of 5 (permalink) Old Jun 23rd, 06, 10:17 AM
Admin edited...
Last edited by DjD; Jun 23rd, 06 at 10:46 AM. Reason: soliciting in forums is not allowed...
dukeme is offline
Edelbrock carb problem? fuel drip, hesitation and backfire -please HELP! mr69 Troubleshooting 6 Aug 7th, 11 07:06 PM
popping back through the carb. biil9 Troubleshooting 7 Feb 10th, 06 07:13 PM
Funky carb problem travis Performance 3 Mar 9th, 05 02:10 PM
Carb float problem mowrey1999 Troubleshooting 3 Jun 11th, 03 01:50 PM
Tuning problem on Edelbrock 600cfm carb. Help please. mikenhis69 Performance 12 Jun 8th, 01 12:06 PM
