Possible hose missing? Pictures. Need Help. - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 25th, 06, 02:36 PM Thread Starter
My 91 Camaro RS V6 hasn't been running for several weeks now. It will start and run in park, but applying gas will kill it immediately. I've replaced the distributor, cap and rotor (one month ago), spark plugs, spark plug wires (a few months ago), catalytic converter, fuel filter, air filter and I've run a compression test which yeilded great results. When I was replacing my ignition coil yesterday, I discovered a tube with a barbed tip. It seems like a vaccum hose should run there, but I have absolutely no clue as to where it would go. Does anyone know if a hose should be hooked up here? This is right next to the externally mounted ignition coil. Thanks.
SactownSunsFan is offline
post #2 of 5 (permalink) Old Jun 26th, 06, 03:20 AM
Re: Possible hose missing? Pictures. Need Help.
Look to see if there is a vacuum hose diagram on the hood. It would be the same as the engine tune-up specs, FED emissions sticker, providing the hood is OE.
If hood has been replaced, pretty good chance sticker won't be there.
If nipple has full manifold vacuum on it, this would be a good reason why it doesn't run after cold start-up. Lean mixture.
post #3 of 5 (permalink) Old Jun 27th, 06, 07:37 PM Thread Starter
Thanks for the reply Everett. I downloaded the vacuum hose diagram off the internet (and found it under the hood too), but alas to no avail, as I'm horrible at reading this thing.
Does anyone have a similar year Camaro RS V6? If so, can you look under the hood and tell me definitively if a hose runs to this nipple? I would greatly appreciate it.
post #4 of 5 (permalink) Old Jun 27th, 06, 08:55 PM
The part shown in your picture looks like a stud originally used to hold a spark plug wire retainer and is not a vacuum nipple at all. If you look at the other end of the part in question, you will probably find that it screws into the coil bracket like a bolt or is possibly riveted in. GM used these with plastic plug wire retainers that slip over the stud.
As far as your problem, it sounds like it's running too lean. The first thing to do is to check the fuel pressure and see it it's up to spec, particularly when it dies out while applying throttle.
red67camaro is offline
post #5 of 5 (permalink) Old Jun 27th, 06, 09:23 PM
plug it and see what happens?
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
power steering hose? JimM Brakes, Suspension & Steering 3 Jun 18th, 06 08:35 AM
RS hose sizes and routing john68conv Tech 2003 13 Dec 23rd, 05 06:17 PM
Stainless Steel Braided Hose Problems camaro man Performance 9 Nov 17th, 03 08:28 AM
Pictures of front brake line to hose? MStennes Brakes, Suspension & Steering 6 May 27th, 03 03:33 PM
Heater Motor Hose? Joe G Tech 2000 8 Mar 17th, 01 06:05 PM
