horn not working - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 28th, 06, 01:17 PM Thread Starter
Steven
stamatisg1977's Avatar
horn not working
hi,
all of a sudden my horn doesnt work. i have all new wiring from A-A. the relay gets too hot to touch.so i removed it for now. ther is power going into the relay and i can see it making the circuit when i have the cover off. before it used to just click when i pusshed the horn now the relay stays closed all the time when its connected. i recently installed a new grant steering wheel, turn canceling cam and turn signal switch assembly. oh and when i disconnect the harness on the sterring column the relay opens but i tried grounding it to see if it makes the horn sound and nothing happens
sorry for long confusing post guys
steve
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 2 (permalink) Old Jul 1st, 06, 04:14 PM
Blaine
Re: horn not working
did it work fine before you put on the new steering wheel?
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
blainedoe is offline
horn contact / cancel cam rodek Interiors 3 May 25th, 06 09:38 AM
Help with '68 Wood Steering Wheel Horn Cap Installation on a Tilt column ggkeller Interiors 2 Jun 29th, 05 05:32 PM
Horn not working. llpainter Electrical & Wiring 2 Apr 24th, 05 07:53 PM
Horn relay problems 69 Blk69 Electrical & Wiring 4 Dec 2nd, 01 04:10 PM
Lights,power windows, horn quit working dragcamaro88 Electrical & Wiring 6 May 8th, 01 09:16 AM
