Will not crank at operating temp? - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 30th, 06, 07:30 PM Thread Starter
Todd
Question Will not crank at operating temp?
I hope someone can help! I own a 1981 Z/28 that will not crank at operating temp. I have 12.5 volts at battery at the time it will not crank. I think it may be the starter getting to hot, But not sure. Has anyone seen this problem?
fasthotrodtodd is offline
post #2 of 7 (permalink) Old Jun 30th, 06, 08:10 PM
Russ
Re: Will not crank at operating temp?
Yes it could very well be your starter getting too hot. do you have headers on the car? Could also be that your timing is too far advanced.
19694speed is offline
post #3 of 7 (permalink) Old Jul 1st, 06, 02:44 AM Thread Starter
Todd
19694speed, Thanks very much for your reply. And yes the car has headers. I thought I might try a header wrap, to keep heat away from stater. Or a factory heat sheild. Will the factory heat sheild work with headers? As far as the timing, I checked and its ok. Thanks again for any information.
post #4 of 7 (permalink) Old Jul 1st, 06, 04:40 AM
Randy
Does it just click and do nothing? Or does it crank but reeeal slow? If it wants to crank your problem is definatly an over heated starter. For that I would highly recommend a heat wrap to go around the starter. They are very effective and are cheap and easy. If it just clicks it could be either the starter OR the solenoid. For that you need to get a f*rd style remote solenoid and mount it away from the heat source. Or be like me and just do both and never have to worry about it.
Randy
rlovell383 is offline
post #5 of 7 (permalink) Old Jul 1st, 06, 07:21 AM Thread Starter
Todd
rlovell383, It will not even click. Its like you took the battery off of the car. I can jump it with my truck. Or I can let it cool for about an hour or so, And it will start right up. Thanks for your reply. Todd
post #6 of 7 (permalink) Old Jul 1st, 06, 09:11 AM
VINTAGE CERT
Sounds like your solenoid is frozen from the header heat. They do make a hi temp solenoid for that problem.I purchased one from mccp 815-648-1700
Vintage Camaro
shaugs is offline
post #7 of 7 (permalink) Old Jul 1st, 06, 11:45 AM Thread Starter
Todd
Shaugs, Thank you for the information on the high temp solenoid. Todd
acceptable operating temp for ss396? fivestarstudios396 Heating & Cooling 6 Feb 21st, 06 11:12 AM
Crank it Up! Larger Dave Engine 1 Jan 30th, 06 04:18 AM
What's the normal operating temp for a fastburn 385 Midlife Cruiser Heating & Cooling 1 Jan 8th, 06 11:37 PM
Operating Temp & Tuning CamFrk68 Engine 5 Jul 6th, 03 08:38 AM
Engine dies once operating temp is reached. Raven87 Troubleshooting 8 Mar 4th, 01 07:50 PM
