Bad Vib's - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 5th, 06, 05:01 PM Thread Starter
Bad Vib's
I have a '67 camaro that still shakes starting at about 60 mph. I have rebuilt the front end (all stock except for I cut a coil from the springs), I have new BFG's and new American Racing aluminum wheels, balanced the drive shaft...and I still have the same heavy vibration that I had at the start. I cannot feel the shake so much in the steering wheel, as I do in the seat (start the bad jokes here!!). Does anyone have any suggestions on what to look at next. All the items listed above were in bad shape and needed replaced/rebuilt, so I'm not just throwing parts and money at it.
cospringscamaro is offline
post #2 of 5 (permalink) Old Jul 5th, 06, 05:31 PM
Robert
Re: Bad Vib's
what engine/trans combo and what rear end. I had a bit of a driveline vibration that was solved by a friend properly setting up the rear end. I think the folks here can point you in the right direction provided they have enough information. I cannot offer specific info on what he did but after he worked on the car the vibrations were gone.
We do not possess imagination enough to sense what we are missing.
robert68 is offline
post #3 of 5 (permalink) Old Jul 20th, 06, 05:19 AM
Re: Bad Vib's
Here's a nice .pdf document on chasing down vibration gremlins in a first gen Camaro: http://csgbenefits.org/camarovibration.pdf
Also, below is from another post -
Cyclic vibrations are usually due to an angle issue with the drivetrain. Randy's Ring and Pinion has some usefull info on vibrations.
http://ring-pinion.com/content/techn...lt.asp?pid=114
Good article on driveshaft angles.
http://superchevy.com/technical/engi...203sc_driving/
Basically, angle A should equal angle B, both vertically and horizontally.
Dave F. in Rhode Island
Chevy-SS is offline
post #4 of 5 (permalink) Old Jul 20th, 06, 05:36 AM
Re: Bad Vib's
JUst for grins try rotateing the shaft 180 degrees at the rear yolk. It did help mine, however changing the body bushings finished it. I had a light vibe around 70 . I installed O.E. style body bushings and walha!
blue ss is offline
post #5 of 5 (permalink) Old Jul 29th, 06, 06:45 PM
Bill
UCDOG's Avatar
Re: Bad Vib's
Check your rear axles also, one of them could be bent.
ucdog aka Bill
1969 Camaro Z28 "recreation",350 sb,tko 600, 12 bolt/410, 4 wheel Wilwood disc brakes, and 17" Tourqe Thrust rims.
UCDOG is offline
Steering Box question- bad bearings? faninc Brakes, Suspension & Steering 3 Jul 9th, 06 02:03 PM
Bad window switch or bad motor Meanchicken Electrical & Wiring 2 Oct 3rd, 05 05:41 AM
Things are BAD BAD BAD rich pern Bench Racing 1 Aug 30th, 05 10:04 PM
torque converter bad? topdown69 Transmission & Driveline 2 Jun 28th, 05 11:30 AM
Even The Top Of The Line Has Its Bad Days bigdawginva Electrical & Wiring 0 Apr 21st, 05 05:19 PM
