69 Power Steering Hose - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 6th, 06, 08:38 AM Thread Starter
Replaced my pressure side power steering hose on my 69 camaro and now it leaks. The question I need answered is this. Does the end of the hose that goes into the gear box require a oring? I have been getting conflicting answers from the local parts stores. Any help would be greatly appreciated. Thanks
grossmj is offline
post #2 of 3 (permalink) Old Jul 6th, 06, 09:48 AM
Vince
Re: 69 Power Steering Hose
No there is no oring at that connection.
3forme is offline
post #3 of 3 (permalink) Old Jul 6th, 06, 06:28 PM
GM Power Steering Hose Connections - Before 1980
All GM power steering connections up until 1980 were 45 degree double flare. Some Chevrolet pumps up until around 1970 had a male fitting and required a power steering hose with a female nut. After 1970, all GM pumps had a female discharge fitting and required a hose pipe with a 45 degree double flare and had a male 5/8-18 nut.
The power steering hose pipe at the gear was 45 degree double flare with a male 11/16-18 nut.
GM Power Steering Hose Connections - 1980 and After
Starting in 1980, GM changed to metric connections that required hoses with an o-ring seal on the pipe. The pump discharge fitting was female with a metric thread. The hose had a male 16x1.5mm nut and the tubing had a special form to accept an o-ring.
The connection at the gear was an o-ring with a 18x1.5mm male nut.
So unless you are using a later model gear or pump in your car, you would be using a hose with a 45 degree double flare end.
JIML82
JIML82 is offline
Steering Column reassembly Steptoe Camaro Tech 17 Jan 23rd, 07 08:48 PM
Carb Dates DZ Fool Tag Team 16 Apr 2nd, 06 11:44 AM
'69 power steering return hose clamp Camaro Billy Brakes, Suspension & Steering 2 Mar 9th, 06 04:10 AM
Power steering high pressure hose install 69 money pit Engine 4 Mar 9th, 03 09:28 AM
Power Steering Hose Failure. Ideas? Scoop69RS-SS Tech 2002 10 May 3rd, 02 05:21 PM
