help! cant start! - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 7th, 06, 06:08 PM Thread Starter
help! cant start!
had car running fine. shut off yesterday. cant restart. i have spark and the wierd thing is if i dump gas down carb, it still does not start. what else is there to check? suggestions? THANKS in advance!
68327camaro is offline
post #2 of 8 (permalink) Old Jul 7th, 06, 10:11 PM
Re: help! cant start!
Did you move the distributor? The timing might be off.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 8 (permalink) Old Jul 7th, 06, 11:02 PM
That is what I'd look at, if the distributor was moved. The hold down bolt could be loose and it migrated.
Also, check to make sure your starter is turning fast enough to get the engine started. If its cranking too slow, it won't start.
Torque your manifold down to the proper specs. ( on a big block it is 25 pounds ) make sure your carb is tight too. A massive vacuum leak won't help.
Getting back to the electrical, check to make sure your block is grounded well. If its not, the starter may still turn the engine but not well.
Also, make sure you check all or most of your cylinders to see if you're getting spark to them all. Bad wires or distributor can sometimes send spark to just a couple of plugs. This is something that can happen over night. I had a cracked dist cap once. It must of cracked after I shut down for the night. When I attempted to start the next day, no diggety.
I ended up taking it to a garage and they immediately found a bad distributor cap that was cracked all the way through.
Just some suggestions.
Hope it helps, good luck friend.
mkpatrick is offline
post #4 of 8 (permalink) Old Jul 8th, 06, 04:41 AM Thread Starter
didnt touch the distributor. but i guess ill go buy a new cap/rotor just to be safe. new plug wires and did check a couple of cylinders for spark, will try a few more. thanks for suggestions!
post #5 of 8 (permalink) Old Jul 8th, 06, 06:22 AM
Doug
DougP's Avatar
HEI distributor? If not, maybe the coil took a dump?
==Doug
Former
owner
Former
owner
Former 2nd
owner (
DougP is offline
post #6 of 8 (permalink) Old Jul 8th, 06, 04:13 PM
If you have spark, is the timing correct? The distributor may have moved, the rotor may have come loose? the timing chain may have skipped a tooth.
Just some thought starters.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #7 of 8 (permalink) Old Jul 8th, 06, 04:53 PM
Does it skip like it's trying to start or just turn over without even acting like it wants to start?
67 Plain Jane is offline
post #8 of 8 (permalink) Old Jul 9th, 06, 05:33 AM Thread Starter
apparently it must have been a cap problem. i had cheked spark on 2 of the cylinders, and made a bad assumption. anyway, replaced cap + rotor, primed carb and she stared right up. thanks for everyones help!
To Start OR NOT to Start, that is the question! jt5by5 Camaro Tech 17 Apr 11th, 06 08:03 PM
intermidiat no start crasher Electrical & Wiring 0 Jul 30th, 05 09:36 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 01:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 01:57 PM
