88 2.8L Check Engine Light flickers KOEO - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 8th, 06, 09:11 PM Thread Starter
Angry 88 2.8L Check Engine Light flickers KOEO
I have an '88 Camaro 2.8, I replaced the ECM because it wasn't commanding the Air pump diverter valve on when activated with the Scan tool. After replacing the ECM and turning the key on the Check Engine Light(CEL) would flicker and the car would barely run when started. I tried a second ECM with the same results. Power and grounds to the ECM are good. Was possibly thinking I had a bad Prom and would like to know if anyone had a similar problem. CEL was on steady before ECM was replaced with KOEO.
edhunt0r is offline
post #2 of 2 (permalink) Old Jul 8th, 06, 09:43 PM
ZZ_430's Avatar
Re: 88 2.8L Check Engine Light flickers KOEO
Sounds like bent pins on the PROM.
They can be carefully straightened. I use an X-acto knife.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
Lobe Separation Angle questions 69ProTouring Performance 19 Oct 10th, 05 05:41 PM
85 iroc check engine light 85iroc Troubleshooting 8 Sep 10th, 02 04:29 PM
check engine light lest13 Tech 2000 1 Jun 22nd, 01 02:03 AM
Check Engine Light Is Moody!! FlyinCamaro Troubleshooting 2 May 6th, 01 05:48 PM
Idles and accellates rough, but no check engine light rhythmdemon Troubleshooting 3 Apr 16th, 01 02:11 PM
