New starter issues - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 15th, 06, 11:32 AM Thread Starter
New starter issues
I just put in a new starter (powerhouse) 153 flexplate. Without any shims, starter starts great then wines while running. One shim, starts great but grinds while running. Seams like gear in starter is not going back in all the way. I havent let it run long enough to jump out and look under car to confirm that though. Any ideas or suggestions? 350 sb automatic straight bolt pattern starter
68RSinWorks is offline
post #2 of 7 (permalink) Old Jul 15th, 06, 11:39 AM
Re: New starter issues
it does sound like the starter is too close to the flexplate, and is not returning, rather binding and sticking.
It's real hard to access those gears to check clearance with the trans in place, but one thing not so hard to do would be to remove the solenoid off the starter and work the bendix by hard to check the alignment.
Is it's like a stock starter, it's just a couple screws and a tiwst to get it off.
Be sure to disconnect the neg battery cable before messing around here.
post #3 of 7 (permalink) Old Jul 15th, 06, 12:32 PM Thread Starter
Solenoid is build on. It doesn't come off. (one of those mini starters)
I shimed it some more. Still starts great, but doesnt go back all the way in. I diid jump out check it with it running. Saw sparks. (teeth are all ok still on both starter and flex) I tested the power at the solenoid start terminal. When you let go of the key it loses power as it should. Is there any chance there are electrical issues with the inside of the solenoid. (Brand New by the way) or is it still a shimming issue? I'll try anything (Even a sledge hammmer on it, if would help )
post #4 of 7 (permalink) Old Jul 15th, 06, 01:03 PM
the only way to know would be to observe or measure the gear clearance.
The only way I've ever measured it is with the trans off and the solenoid off, pull the bendix drive out by hand and measure the clearance between the gears, a paper clip should just fit between the engaged gear teeth.
I've also done it with everything together, just by working the bendix with the solenoid off and "feeling" the gear engagement.
The solenoid won't come off that thing?
Is there a way to disconnect the power lead from the starter to the solenoid like you can with the stock starter, then you could engage it with the key without the motor spinning and perhaps see what's happening better?
post #5 of 7 (permalink) Old Jul 15th, 06, 01:52 PM
There should be .030 clearance at the teeth (point of one to between other if you get what I'm tring to say) I used a large paperclip and screwdriver to check gap. Its had to do but needs to be checked.
68 Camaro~LSx ~all motor
post #6 of 7 (permalink) Old Jul 15th, 06, 06:29 PM
Brad
Do you have the starter wired correctly? I think if one of the starter wires are on the wrong terminal the starter will stay engaged even with the key on the "run" position. Just thought Id mention since you did, im assuming convert from standard starter and the connections are a little different. 1 less wire on the mini I believe.
Most recent 01/01/10
spideynut is offline
post #7 of 7 (permalink) Old Jul 15th, 06, 08:41 PM
hmmm, spidy might be on to something. What wires are on your starter? Those mini starters only have 1 small terminal, for purple wire only. If you have a yellow wire, it should NOT be connected.
69 Ignition / Starter Issues - HELP! Rack Man Electrical & Wiring 10 Mar 27th, 06 07:18 PM
69 z28 starter and elctrical issues Cpz28 Camaro Tech 4 Sep 23rd, 05 05:12 AM
Starter issues with Proform starter X33camaro Electrical & Wiring 4 Aug 22nd, 05 08:44 PM
Starter Tech JimM Electrical & Wiring 2 Sep 21st, 04 09:41 AM
starter teeth problem. flywheel grinding Marc Engine 6 Jul 7th, 03 01:53 AM
