'87 IROC TPI idle stall w/air on - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 17th, 06, 08:28 PM Thread Starter
Call me Jim
Send a message via AIM to brightblue87iroc
Cool '87 IROC TPI idle stall w/air on
A couple of times lately in very hot weather I've cranked my IROC up with the engine cold, turned the a/c on, and the engine will die. Trying to restart it will run a few seconds, then die again, sounding like it's loading up, and the Service Engine light will come on. Once the air gets cooler the car will run fine as long as I don't turn the air on. The computer stores no codes and resets itself. I've been told it could be the IAC valve, the coolant temp sensor, fuel pump....etc. One knowledgeable fellow suggested an "Idle Re-learn" sequence, which I'll try if it does it again. I know next to nothing about TPI, and any help from you TPI wizards out there would me greatly appreciated.
brightblue87iroc is offline
post #2 of 2 (permalink) Old Jul 17th, 06, 08:53 PM
ZZ_430's Avatar
Re: '87 IROC TPI idle stall w/air on
Sounds like you should take the IAC out and clean it. It could have a build-up of carbon on the pintle and the passage. You could clean with carb spray.
Also the throttle blades could be dirty around the edges and the back side of the shaft. It doesn't take much.
So basically, clean the throttle body and remove what they call "coking".
As far as an "idle learn" that usually applies to a motor with an Idle Speed Control motor. (ISC)
It is done with the motor at operating temp, go into diagnostics, and run at idle for a couple of minutes in gear, then turn AC on and run for a couple more, and then put back into park and turn off key.
And it isn't setting a code when the check engine light comes on, it could just be that under 400 RPM or so, the ECM sees no distributor signal. (Code 12)
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
MAF TPI rough idle shuanm Engine 1 Mar 27th, 06 03:23 AM
stall speed tech mmcillece Performance 0 May 15th, 05 08:35 PM
Holley tuning? railing68 Performance 22 Feb 13th, 05 03:55 AM
Holley tuning question wizard67 Performance 22 Sep 20th, 04 04:05 PM
My 1st Big Cam/ Trying to adjust Carb/Low Vacuum PERKS67-396 Engine 20 Oct 4th, 02 09:14 AM
