I want my camaro back - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 19th, 06, 03:01 PM Thread Starter
Ok, here is the story, I have a 1994 LT1 camaro. The heads went bad, so me and my dad decided to change them ourself. Which was good. Everything went ok. The only problem is we have pretty much everything back on now, but the engine just will not fire. We only tried for about 15 minutes, but I just don't want to put anything else back on until we know what the problem. Because changing heads on an LT1 absolutely sucks. Anyways, is there anyone that can help with anything. I am lost. Thanks everybody.
Barkley254 is offline
post #2 of 4 (permalink) Old Jul 19th, 06, 03:13 PM
click's Avatar
Re: I want my camaro back
did you happen to get the distributor 180 degrees off? It wont fire if you did but it will turn over easily.
click is offline
post #3 of 4 (permalink) Old Jul 19th, 06, 03:57 PM
On the LT-1 you should not have needed to remove the distributor to change the heads, however you had to remove the coil and module. Do a simple double check to make sure ALL the connections are correct and making contact. Ask me how I know...
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #4 of 4 (permalink) Old Jul 19th, 06, 08:27 PM Thread Starter
lol, i think i know how you know. Ok, I have to plugs that I cannot find where they go at all. one is on the passenger side directly over the valve cover. the other is on the bottom on the drivers side under the exhaust manifold. this sucks. lol. by the way thanks for everything.
Could the camaro be back ? is it a camaro? blue ss Bench Racing 33 Oct 13th, 05 04:02 PM
Camaro is back????? GMJim Bench Racing 3 Oct 12th, 05 12:43 PM
CAMARO IS BACK IN 2007!!!!!!!!!!!!!!!!!!!!!!!!! dawg Bench Racing 32 Apr 24th, 05 07:27 PM
Its been a few years but here I am back at Team Camaro! Toby T. Bench Racing 8 Feb 2nd, 05 11:39 AM
