gas in oil - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 24th, 06, 04:18 AM Thread Starter
gas in oil
put new fuel pump on still getting gas in oil. car running rich out exhaust will burn eyes and smokes on both side of exhaust. can hear a compression leak on drivers side of engine. could this be a blown intake gasket now letting gas into engine????
coleman68 is offline
post #2 of 3 (permalink) Old Jul 28th, 06, 03:24 PM
Russ
Re: gas in oil
I don't think your intake gasket being bad would be the cause of gas getting into your oil however that has to be replaced for sure If indeed you do have a bad gasket. It could be that your pump or pumps on the carb are set too tight and when you shut the car off gas leaks down into the manifold and then into your engine oil.Do you smell gas after you shut the car off?An easy way to check is to have the air cleaner off when you shut the car off and have a look down into the carb to see if any gas is still leaking down or you may even see smoke coming out of carb indicating a gas leak,It's worth a try.
Russ
19694speed is offline
post #3 of 3 (permalink) Old Jul 28th, 06, 07:55 PM
AJ
Re: gas in oil
r u sure there is actually fuel in the oil?
or does it just smell really really rich?
how big is ur carb?
single or dual plane manifold?
how is the ignition? (could be a weak spark and not fully igniting the fuel).
ace's68 is offline
Oil Change Procedures for Women emperor91108 Bench Racing 9 Apr 8th, 12 10:10 AM
Funny but true oil change differences men/women b-boy Bench Racing 7 Jul 11th, 06 12:23 AM
Oil Change MRCOOL_RSSS350 Bench Racing 1 Apr 16th, 06 06:48 PM
HELP! Oil in Gas bobbys1967 Engine 1 Oct 22nd, 05 04:30 PM
