Tachometer problem - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 24th, 06, 09:04 AM Thread Starter
Tachometer problem
I have an 80 Z28. When I am spinning the engine up past about 4700 the tach starts to jump around. ANy ideas?
DirtyScotty is offline
post #2 of 6 (permalink) Old Jul 24th, 06, 10:06 AM
Banned
Chet
Question Re: Tachometer problem
Factory tach? Factory ignition?
154567 is offline
post #3 of 6 (permalink) Old Jul 24th, 06, 10:36 AM
Might need a HEI ignition module.
post #4 of 6 (permalink) Old Jul 24th, 06, 10:53 AM Thread Starter
Mallory HEI and factory tach. When I have the timing light on it the tach seems very accurate. It is just when you are on a run going past 4700 the tach gets wacky and I am not sure if I am approaching my 5900 shift or not.
post #5 of 6 (permalink) Old Jul 24th, 06, 12:14 PM
I would exchange/borrow an HEI ditributor just to see if this swapout corrects the problem.
If it did, then I would know where the problem is at and fix it from there. You might give MSD a call with all part numbers, stock & MSD, and ask for their advice.
post #6 of 6 (permalink) Old Jul 24th, 06, 02:01 PM
This sounds like another manifestation of the sqaure wave vs. syne wave tach signal again. I would try this inexpensive filter:
http://home.comcast.net/~jimragtop/tachfilter/index.htm
markr is offline
In Need Of Major Help!! Please!! Justgotacamaro Engine 31 Mar 6th, 07 05:22 AM
Air Conditioning Problem Mark C Heating & Cooling 21 Jul 17th, 05 10:16 AM
Holley problem SICKT9 Engine 5 Jun 11th, 05 02:21 PM
BBC engine Vacume problem 68and69ss Troubleshooting 4 Jun 1st, 05 05:49 AM
arcing problem camaro-69ss Electrical & Wiring 2 Apr 6th, 05 08:59 PM
