throttle getting stuck - Team Camaro Tech
post #1 of 9 (permalink) Old Jul 28th, 06, 10:59 PM Thread Starter
Chris
Cool throttle getting stuck
my sons Camaro throttle had gotten stuck when he took off..what could it be? bad spring? what would you recomending doing? thanks for any help..
Muscle cars were loud, proud, and in your face, and did not pretend to be anything else.
69camarofast is offline
post #2 of 9 (permalink) Old Jul 28th, 06, 11:12 PM
Vince
Re: throttle getting stuck
Motor mount Chris.
3forme is offline
post #3 of 9 (permalink) Old Jul 29th, 06, 12:14 AM Thread Starter
Chris
Cool Re: throttle getting stuck
thanks i have new motor mounts, but will check them again..i read through some old threads and will check carpet, springs,air cleaner..
post #4 of 9 (permalink) Old Jul 29th, 06, 12:28 PM
I went through this with my 69. Mine has a rod, not a cable. When you install the rod you have to make sure both ends face the passenger's side of the car like this [ or it will bind at wide open.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #5 of 9 (permalink) Old Jul 29th, 06, 12:33 PM Thread Starter
Chris
Thanks..12run..it will happen once in a while, not making corners ....so i think it might have somthing to do with the rod or air cleaner?
post #6 of 9 (permalink) Old Jul 29th, 06, 09:42 PM
Chris, Also check the bushings on the throttle. You might have one that came apart on you or is loose causing a bind.
Camaro buds until the end!!!
Camaro Dave is offline
post #7 of 9 (permalink) Old Jul 30th, 06, 12:36 AM Thread Starter
Chris
ok, thanks..i will also check it...
post #8 of 9 (permalink) Old Jul 30th, 06, 05:09 AM
Check with engine off, and have someone looking/feeling linkage assembly while going to WOT position.
Something is binding or snagging. Some possibilities:
* as stated, broken motor mount allowing engine to lift,
* pedal catching carpet,
* swivel joint on firewall binding,
* swivel arm is snagging on a wire or oil pressure sending line,
* linkage hitting air cleaner,
* as stated, bushings on throttle rod,
* as stated, bent throttle rod,
* wrong clips for throttle rod,
* carb plates maybe sticking,
* weak return spring.
Actually, you shouldn't even need a return spring. I mean, I always use one, but even without a return spring, the carb should close itself easily. Every carb has built-in springs.
Dave F. in Rhode Island
Chevy-SS is offline
post #9 of 9 (permalink) Old Jul 30th, 06, 02:07 PM Thread Starter
Chris
Thanks, i will print your list.. ..i will go through and check everything
69 Ss Throttle Cable Upgrade JAKER110 Camaro Tech 7 Jul 26th, 06 10:28 PM
Throttle body help! CamaroCT Engine 9 Jun 30th, 06 03:52 AM
Throttle Getting Stuck JBCAMARO Performance 22 May 11th, 05 10:59 AM
My 1st Big Cam/ Trying to adjust Carb/Low Vacuum PERKS67-396 Engine 20 Oct 4th, 02 09:14 AM
Stuck throttle linkage!!!! m1a1r1k1 Tech 2000 8 May 30th, 00 04:22 AM
