No Spark Hhellppp - Team Camaro Tech
post #1 of 14 (permalink) Old Jul 31st, 06, 09:52 PM Thread Starter
Exclamation No Spark Hhellppp
i have no spark, new pick up coil, ignition coil, ECM, dist. cap and rotor, new plugs, wires are good, all fuses are good, dont knwo what to do...
Ground wires??? Shorts in elecrical system? where to look
COBHC86 is offline
post #2 of 14 (permalink) Old Jul 31st, 06, 09:52 PM Thread Starter
Re: No Spark Hhellppp
Help Me
COBHC86 is offline
post #3 of 14 (permalink) Old Jul 31st, 06, 10:58 PM
AJ
is it an h.e.i coil in the cap??
ace's68 is offline
post #4 of 14 (permalink) Old Aug 1st, 06, 04:40 AM
Do you have voltage at the ignition system?
Do you have a good ground contact?
post #5 of 14 (permalink) Old Aug 1st, 06, 04:46 AM
what year make model car we talking about?
firstgen camaros don't have ecm's....
post #6 of 14 (permalink) Old Aug 1st, 06, 09:05 AM Thread Starter
this is a third gen camaro, 1986 2.8L V6 MPI
COBHC86 is offline
post #7 of 14 (permalink) Old Aug 1st, 06, 10:11 AM Thread Starter
how do i check for voltage at the ignition system, i have a volt/ohm meter, but where would i check?????
COBHC86 is offline
post #8 of 14 (permalink) Old Aug 1st, 06, 10:17 AM Thread Starter
i also check continuity from my battery and the main ground and they have a solid 12volts.....i really need help figuring this out....i need this car back
COBHC86 is offline
post #9 of 14 (permalink) Old Aug 1st, 06, 10:25 AM
ZZ_430's Avatar
The coil has 2 small primary wires (red and white) that plug into it.
Take a 12v test light with a sharp point, and check the white wire while cranking. (with the connector still plugged in)
It should flash.
If it doesn't, I would suspect the ignition module in the distributor since you say you already replaced the pickup coil.
How have you determined there is no spark?
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #10 of 14 (permalink) Old Aug 1st, 06, 07:04 PM Thread Starter
Exclamation Re: No Spark Hhellppp
i know there is no spark because i took all the plugs out and grounded them and checked for spark, and i checked for spark from the i9gnition coil its self, and the ECM IS new, or is and ignition module someting different than the ECM??
COBHC86 is offline
post #11 of 14 (permalink) Old Aug 1st, 06, 07:10 PM Thread Starter
im tihnmking that there might be a short in he wiring harness or maybe my ECU is bad???....and i dont want to take it to a garage because i would only take it to elms and they want $70 and hour.....but i dont know where to begin looking for a short anywhere?
COBHC86 is offline
post #12 of 14 (permalink) Old Aug 1st, 06, 07:17 PM Thread Starter
when the car died this time, it spit and sputtered for about 5 minutes and then just completely died, and hasent started since, and then i replced the pick up coil and it didnt work.....and im not sure where the ignition module is?
nless your talking sabout the ecm, and if you are thats brand new, ive replaced it twice......
COBHC86 is offline
post #13 of 14 (permalink) Old Aug 1st, 06, 08:28 PM
ZZ_430's Avatar
As I mentioned in my first post, the ignition module is located in the distributor.
ZZ_430 is offline
post #14 of 14 (permalink) Old Aug 1st, 06, 08:39 PM Thread Starter
yea i replaced that, the ECM (Engine Control Module) ive replaced it twice....
COBHC86 is offline
1973 Camaro Won't Start, No Spark.... 73CamaroSC Engine 11 Jun 9th, 06 07:34 AM
Spark no spark dlowery Performance 9 Jan 8th, 06 08:16 PM
Rewiring the car... mbmmca Electrical & Wiring 13 Nov 23rd, 05 12:27 PM
Help-- Lousy spark Unreal Engine 3 Jun 6th, 04 10:24 AM
car wont start after spark plugs changed [email protected] Tech 2000 4 Apr 6th, 01 07:13 PM
