LT-1 troubles - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 6th, 06, 08:44 PM Thread Starter
LT-1 troubles
I have a '94 LT-1 that will sometimes quit for no reason like it's running out of fuel or has no spark. It will start fine if it's been sitting a while, but when you drive it for some time it will die going down the road and sometimes not start if it's hot. I put a dynatech distributor on it and seems like it started after that, but not sure because I don't drive it much. Any help or similar experiences would be appreciated.
Mauler is offline
post #2 of 3 (permalink) Old Aug 6th, 06, 09:41 PM
madmax87's Avatar
Re: LT-1 troubles
A friend of mine just had a similar problem except his started to run bad after running awhile. It ended up being his fuel pump. Would start sometimes after letting it sit, but once he stopped it and turned off, it would not restart. His was a 97 LT1. I would invest in a pressure gauge and check your fuel pressure.
madmax87 is offline
post #3 of 3 (permalink) Old Aug 14th, 06, 01:03 PM
Tim
Re: LT-1 troubles
auxillary power cable that goes to the fuse box in the engine compartment. The post the extra positive runs to . . .
The bolt gets corroded ( replacement bolt is brass instead of steel).
replace the bolt. No more problem. Check it out. You most likely have an intermittent loss of power to that box.
That is what happened on my LT-1 caprice. My uncle could never figure it out. I bought the car from him . . . I fixed the problem . . . no problem for 5 years.
Good luck.
Tim
Ratchetmaster
1968 SS Merlin III PBM Performance Products 572 with all the good stuff, Dart PRO 1 aluminum heads, Jesel roller rockers, Steel 4340 scat crankshaft, PBM rods, SRP forged pistons, Billet specialties, Be Cool radiator package , Tremec TKO 600 5 speed, Moser 12 bolt, Hotchskis, Baer, etc.
1968 RS SS 350 M4
1969 Olds 442 convertible
1972 454 ElCamino Turbo 400 (X now owns it! )
1973 RS LT Z28 M4 SOLD
2006 Silverado Duramax lbz Crew Cab SB 4x4
ratchetmaster is offline
Torque converter troubles... 02renegade Transmission & Driveline 10 Jun 8th, 06 01:26 PM
carb troubles 67stang Engine 8 May 11th, 06 06:52 AM
T5 troubles chadrafuse Transmission & Driveline 4 Feb 14th, 06 09:13 PM
throwout bearing troubles smokin 67 rs Transmission & Driveline 18 Jan 27th, 06 05:17 AM
spoiler troubles malibuman1 Body Shop 2 Jan 27th, 02 12:41 AM
