Best set up to get engine to start...... - Team Camaro Tech
post #1 of 10 (permalink) Old Aug 10th, 06, 10:52 AM Thread Starter
Chester
When I start my engine cold it starts with a reasonable amount of cranking. After the engine is at temp and I try to start after 30 or more minutes it is difficult to get started. It turns over without any problem it just take a while to start and then it runs fine. I have a hei set up 10*advanced initial. Carb is set up a little lean. Any suggestions?
68 convertible, Grotto blue, 327 TH350,3.08 diff
jacket is offline
post #2 of 10 (permalink) Old Aug 10th, 06, 10:55 AM
Eric
Re: Best set up to get engine to start......
What carb are you running?
ERIC
67 Convertible, 350CID, TKO600RR, 3.73 Eaton Posi
ept000 is offline
post #3 of 10 (permalink) Old Aug 10th, 06, 10:55 AM
Needs to be moved to a tech section.
<TR>
maxharvard is offline
post #4 of 10 (permalink) Old Aug 10th, 06, 11:32 AM
When car is cold, step on the pedal a couple of times. This causes the choke plate to close and an extra gas shot. Engines need extra fuel to start when cold.
When engine is hot, the fuel has probably evaporated from the carb, regardless what brand you have. The reason for the long crank is the mechanical fuel has to fill the fuel bowl back up. Then fuel can be pulled into the intake. You might even try a 1/2 pedal stroke to fuel some from the accelerator pump.
You might even try a different brand of gas. If not your daily driver, it may have a winter blend/recipe.
post #5 of 10 (permalink) Old Aug 10th, 06, 12:32 PM
DjD
DjD's Avatar
Weak spark will effect cold or warm starting. Could be coil, plug wires, plugs and plug gap, cap or rotor. Lack of fuel as already suggested will also cause starting problem. Check your squirters, watch them and move the throttle. If they squirt you have fuel in the bowl(s) and I would say fuel isn't the problem. Make this check before starting the initial time and do it again when hot to proove it out under both conditions.
Also as already suggested, we are use to not touching the gas on our modern computer controled fuel injected cars when starting them. Old cars need a 2 pump in the morning, if they have a choke this sets it and gives a squirt of fuel too. When warm my cars don't need the extra pumps but I have seen many that still need a pump or two... The caution here is learn when you have flooded the engine as then you need to put the pedal on the floorboard until it starts..
...Dennis
DjD is offline
post #6 of 10 (permalink) Old Aug 10th, 06, 01:06 PM
Sounds like your carb float level may be too high. You may want to check it.
'69 Yellow/Black Houndstooth RS/SS, 4 bolt Crate 350/325hp, TKO600 5 spd, A/C, P/S, PDB, Tilt, 12 Bolt Posi 4.10 Gears, Console&Gauges, Rosewood, Cruisin with XM on 70's
'70 Chevelle w/SS add-ons, 350, 700r4
BNZFixr is offline
post #7 of 10 (permalink) Old Aug 10th, 06, 06:14 PM Thread Starter
Chester
Carb is a Q-jet. I think I may need some practice at finding the right "touch" to start get it started quickly.
jacket is offline
post #8 of 10 (permalink) Old Aug 10th, 06, 06:49 PM
Here's my suggestion; but only if you have electric choke........
I had this problem on a couple of different cars. One had Holley carb and the other one was a Q-Jet; both carbs had electric chokes. Finally I figured it out. The electric choke spring cools down much quicker than the engine. So, the engine gets up to running temp, then you park for a few minutes and when you come out, the engine is still hot, however, the choke will activate.
Now let's say you want to start this hot engine, that's been sitting for, say, 10 or 20 minutes. When you go to start the electric choke comes on (even though no choke is needed), causing over-rich starting condition and hard starting.
So, I ended up leaning the chokes out quite a bit and that solved my problems.............
Dave F. in Rhode Island
Chevy-SS is offline
post #9 of 10 (permalink) Old Aug 10th, 06, 06:54 PM
DjD
DjD's Avatar
No you don't need "the right touch"... You need a tune-up...
...Dennis
DjD is offline
post #10 of 10 (permalink) Old Aug 11th, 06, 05:04 AM Thread Starter
Chester
DJD,
I have less than 500 mi on the current plugs, wires, dist, carb, etc. Carb is new and dist is hei. What would you suggest I change? I have found that it starts quicker when I depress the pedal about 1/2 way down when cranking.
Chevy-SS,
The carb does have an electric choke. I have noticed that when It has trouble starting the idle is low initially and then will smooth out after revving the engine.
jacket is offline
Engine won't Start Unreal Engine 7 Aug 29th, 04 07:30 AM
engine builder's code of ethics?? / big block oil pressure ?? caribbean camaro Engine 4 Jul 9th, 03 03:05 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 01:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 01:57 PM
Engine Start Stand... RFrenette Tech 2002 6 Jul 10th, 02 12:53 AM
