cat converter changing or removing - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 12th, 06, 08:05 PM Thread Starter
Question cat converter changing or removing
guys, does any body have information and pictures for how to change or remove the cat converter in a Z28 97 ??
pleaase help!
gentie is offline
post #2 of 3 (permalink) Old Aug 17th, 06, 10:30 PM
Re: cat converter changing or removing
Well, changing a cat is about the same for any vehical. You start at the cat and move down the pipe till you come to the bolts, remove the bolts then the cat. If there are any cross beams, remove them or lower them so you can remove the cat. another way is to just cut the old cat off and weld in or strap on another.
78z28 is offline
post #3 of 3 (permalink) Old Aug 21st, 06, 03:45 PM
I just had to do the same to my 94 Z28. I cut the cat off the car and had a shop weld a new cat on. It cost about 70 bucks for the weld and the bit of pipe they needed to add on. I bought a universal cat from magnaflo and that was $63.00 online at auto parts wharehouse... good luck
richsgirl is offline
95 camaro random q's (catlytic converter, plugs, egr etc.) 95camaro5spd Camaro Tech 2 Apr 25th, 06 12:21 AM
Changing points to electronic ignition converter stevea Electrical & Wiring 10 Jun 16th, 05 10:55 PM
Query on using non lock up converter with my 700R4 caribbean camaro Transmission & Driveline 2 Feb 8th, 04 11:26 AM
What gearing to run with my stall? Luke805 Performance 23 Oct 15th, 02 04:22 AM
torque converter questions matth Engine 8 Mar 8th, 02 10:44 PM
