68 RS Doors open but dont close - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 13th, 06, 11:14 AM Thread Starter
Red face 68 RS Doors open but dont close
I have about given up on this one.
I have checked everything as far as I know to check, and refered to assembly manuel. Installed new check valve, and filter.
As soon as you tun the car on, the doors open.
They do not close. I removed the T fitting,and installed the check valve but, they still do NOT close. They work real slow with the check valve, so I just put the T fitting back in so they would open a little faster. What gives on this?
I guess I need to replace the headlight switch?
1BADRS is offline
post #2 of 6 (permalink) Old Aug 13th, 06, 12:14 PM Thread Starter
Re: 68 RS Doors open but dont close
https://www.camaros.net/techref/articles/rpoz22_1.htm
1BADRS is offline
post #3 of 6 (permalink) Old Aug 13th, 06, 12:29 PM Thread Starter
I have a problem with though as the diagram shows the canister tank only having one opening, when it in fact has two openings instead of one. Anyone?
1BADRS is offline
post #4 of 6 (permalink) Old Aug 13th, 06, 12:30 PM
Hoses are on backwards at the light switch.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #5 of 6 (permalink) Old Aug 13th, 06, 01:19 PM Thread Starter
I did like the diagram, capped off the extra opening on the tank, and still no change. Doors stay open as soon as car starts.
1BADRS is offline
post #6 of 6 (permalink) Old Aug 13th, 06, 01:20 PM Thread Starter
Ok mark.
Ill check that. In fact, Ive got to get up in there anyway, ill just replace the switch when I'm at it, and reverse the hose too.
1BADRS is offline
open & close loop goldyiroc Troubleshooting 4 Jul 19th, 06 05:02 AM
68 Camaro Wiring FUBAR tbird171 Electrical & Wiring 4 Apr 16th, 06 06:07 PM
headlight doors stuck open Chris396 Tech 2000 3 Apr 16th, 01 07:10 AM
67 HEADLIGHT DOORS WON'T CLOSE David Efford Tech 2000 6 Feb 12th, 01 01:45 AM
68 RS Headlight doors partially working Robert Stacho Tech 2000 6 Dec 9th, 00 06:11 AM
