69 rs headlight problem - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 13th, 06, 11:35 PM Thread Starter
Unhappy 69 rs headlight problem
hi, i have a 69 rs camaro. i have installed a complete new rs headlight system. the problem i am having is the headlight doors will not shut all the way. when i shut headlights off they shut, but there is about a 1 inch gap before there closed completely. i can not move the doors by hand as they will not go any further. when i take the actuators completely off the doors work and move great and freely.i have looked to see if there was any adjustment for the length or for the actuators to move. its like the actuator arms are to long. but when i hook everthing back up they open and close great just will not close all the way. help!!!
garyj is offline
post #2 of 5 (permalink) Old Aug 16th, 06, 04:39 PM
Re: 69 rs headlight problem
I believe there is some adjustment available where the actuator mounts to the bracket.
With the actuators disconnected will the doors shut all the way?
BPOS is offline
post #3 of 5 (permalink) Old Aug 18th, 06, 09:38 PM Thread Starter
hi, yes with auctuators off doors shut all the way.
garyj is offline
post #4 of 5 (permalink) Old Aug 19th, 06, 11:03 AM
It seems that the actuator needs to be moved forward. The rear mounting bracket can be moved forward by loosening the two 1/4" bolts that hold it to the rear bracket and moving it forward.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #5 of 5 (permalink) Old Aug 19th, 06, 12:12 PM
Had that problem,, there is no adjustment that I can find,,, figured out that my actuator brackets were bent. Had to rebend them to get doors to close. Think the large front 245 tires caused this on bump turns.
TC # 349
zdld17 is offline
69 kick panel problem.. BlackoutSteve Interiors 17 Jan 13th, 08 06:17 AM
69 Tach problem 154567 Electrical & Wiring 5 Jun 2nd, 06 01:35 PM
Installing 69 RS grill in standard 69 how hard rs/rs Camaro Tech 1 Oct 6th, 05 09:34 PM
Front turn signal/parking lamp problem elcamino72 Electrical & Wiring 1 May 19th, 02 06:23 AM
fuel problem HELP jokerdwarf Troubleshooting 2 Dec 11th, 99 03:17 PM
