Daily driver electrical/starting problem - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 17th, 06, 06:58 AM Thread Starter
Bret
Guys, I need some advice. We bought a '99 suburban last fall and I'm staring to experience some electrical gremlins.
http://www.pro-touring.com/forum/showthread.php?t=17311
I never fully got this issue reolved, but did find that a remote start/alarm system had been inststalled by a previous owner.
The other day the engine would just not start. The battery was replaced just a few months ago. There wa a 'click' sound as if the starter solenoid was activating, but no cranking of the starter. I dropped the starter and had it tested-it was good. Teh click I heard must have been the starter relay in the fuse box? It seems now that no power was getting to the solenoid-just a guess.
At this point, I decided that it was time to remove the alarm system to see if that was the culprit. Especially since I thought it may have been contributing to my previous problem.
The original factory wiring had been spliced in what I would call a 'T' fashion-they stripped about 1/4" of insulation and wrapped the new alarm/remote start wire around the factory wire. So I disconnected all of those connections. Went to hook the battery back up and the starer strated cranking immediately, the key wasn't even in the ignition!!
At this point, I still have the no start problem and my dash is torn apart! I have checked and double checked that the factory wiring under the dash is still intact. Do I need to go back to square one and try replacing the battery cables? What about the starter relay in the underhood fuse box? I feel that I may have gotten in over my head here!! Help??
Bret Copsey
'68 Camaro base coupe
'51 Chevy 3/4ton
bretcopsey is offline
post #2 of 9 (permalink) Old Aug 17th, 06, 01:19 PM Thread Starter
Bret
Re: Daily driver electrical/starting problem
Can someone provide a link to a good wiring diagram at least? The crappy Hanes book is all I have...
Bret Copsey
'51 Chevy 3/4ton
post #3 of 9 (permalink) Old Aug 20th, 06, 05:53 AM
My advice is to consult with a local car alarm specialist. Pay the guy a hundred bucks to come and connect the wires.
If all you're trying to do is get the starter to crank using the key switch, then it doesn't sound like a very difficult issue to solve, provided you have someone familiar with the wiring......
Dave F. in Rhode Island
Chevy-SS is offline
post #4 of 9 (permalink) Old Aug 21st, 06, 06:28 AM Thread Starter
Bret
Turns out the starter solenoid was bad afterall.
Bret Copsey
'51 Chevy 3/4ton
post #5 of 9 (permalink) Old Aug 30th, 06, 07:16 PM
Brad Jackson
Never overlook the most obvious,or the cheapest...
BadBradJ is offline
post #6 of 9 (permalink) Old Aug 31st, 06, 04:40 AM
Yeah, you're definitely right about that. But if you look in his first post, he said he had, "dropped the starter and had it tested-it was good."
As the old saying goes, garbage in - garbage out............................
Chevy-SS is offline
post #7 of 9 (permalink) Old Aug 31st, 06, 05:36 AM Thread Starter
Bret
Not exactly sure what was meant by that. I took the starter to AutoZone, they tested it and the machine said it was good. I then happened across this thread https://www.camaros.net/forums/showthread.php?t=88212 and decided to try replacing the solenoid anyway. It turned out be the problem.
Bret Copsey
'51 Chevy 3/4ton
post #8 of 9 (permalink) Old Aug 31st, 06, 06:44 AM
"Garbage in" = wrong information provided (you said starter was good)
"Garbage out" = wrong diagnosis (based on wrong info)
That's all I meant. No criticism intended.......................................... .
Chevy-SS is offline
post #9 of 9 (permalink) Old Sep 13th, 06, 07:47 PM
george
so much for todays bench tests.We tested starters and drives on the bench and passed them if they could chew up a Sherwood hockey stick and still pull low amps.lol
fatblock is offline
Weird Vibration Problem Cameron Brakes, Suspension & Steering 11 Apr 19th, 06 07:18 AM
Need Help w/"80" Camaro Shifter Problem!!! Robert05 Troubleshooting 2 Feb 6th, 06 10:54 AM
Daily driver problem. I need your help! MytMini Bench Racing 6 Apr 16th, 04 05:20 PM
Accel HEI distributor problem Eric68 Tech 2000 6 Jul 10th, 01 01:16 PM
fuel problem HELP jokerdwarf Tech 2000 3 Dec 7th, 99 06:41 AM
