Key don't go back to lock and come out - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 19th, 06, 04:45 PM Thread Starter
I have a 95 camaro and a while back I had aproblem were when I shut off the car I couldn't turn the key back far enough to get it out. I messed with the wheel long enough and got it out. I went to the dealership and got a new key made and it worked fine for about 6 mounthes and now it's doing the same thing. The original key did appear to be a little bent but this new key has only been used about 6 times and has never even been in my pocket only in the ignition and the spare keybox. I don't usually use this car except for once or so a month to play. Does anyone have a solution or should I tear the steering colume apart and see if I see A problem?
Rick F.
Ferg is offline
post #2 of 3 (permalink) Old Aug 22nd, 06, 04:07 PM
JohnZ's Avatar
Re: Key don't go back to lock and come out
Has nothing to do with the key - adjust the backdrive cable from the trans that moves the lever at the bottom end of the steering column; if that lever isn't pushed all the way up by the cable, you won't be able to turn the ignition cylinder to "lock".
JohnZ
CRG
JohnZ is offline
post #3 of 3 (permalink) Old Aug 25th, 06, 06:18 PM Thread Starter
Thanks I'll give that a try
Ferg is offline
