92 Camaro RS won't Idle - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 21st, 06, 04:29 PM Thread Starter
My wifes camaro started stalling at an idle. Now it won't run correctly. This is what I have replaced and or had checked. Trottle Positioning Sensor, Idle Air Control, Map Sensor, ECM, Water Temp Sensor, O2 Sensor, all have been replaced. The Ignition Control Module was tested. I am running out of parts to replace or test. This may help, if I hold the vacuum line to the map sensor close to but not all the way on the port to the TBI the engine idles fine, all the way off the engine runs real rich, all the way on the engine run lean. Any sugestions would be greatly appreciated. Thank You
Maxwel95 is offline
post #2 of 3 (permalink) Old Aug 21st, 06, 06:50 PM
Smile Re: 92 Camero RS won't Idle
There is no "E" in Camaro !
Check at http://www.3rdgen.org for more 3rd gen info !
TJS69 is offline
post #3 of 3 (permalink) Old Aug 21st, 06, 07:51 PM Thread Starter
Re: 92 Camaro RS won't Idle
oops, my bad typing. how is that, better. Hey Thanks
Maxwel95 is offline
Initial timing setting? RRatchet Performance 4 Feb 6th, 06 09:13 AM
Holley tuning? railing68 Performance 22 Feb 13th, 05 03:55 AM
Holley tuning question wizard67 Performance 22 Sep 20th, 04 04:05 PM
My 1st Big Cam/ Trying to adjust Carb/Low Vacuum PERKS67-396 Engine 20 Oct 4th, 02 09:14 AM
Big Cam Bad Idle :( Badcaiman Tech 2002 16 Jul 6th, 02 05:32 PM
