Book Troubleshooting Suggestions - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 23rd, 06, 08:59 AM Thread Starter
shane mattix
Any suggestions on books regarding engine troubleshooting? I know basics and how an engine works but don't know jack when it comes to troubleshooting problems. Thanks.
smattix is offline
post #2 of 6 (permalink) Old Aug 24th, 06, 12:43 AM
Re: Book Troubleshooting Suggestions
everyone here would be willing to help you trouble shoot a problem if you have the time...
but i am of no help as far as finding any books to help diagnose problem
400bird is offline
post #3 of 6 (permalink) Old Aug 25th, 06, 12:37 PM
Good troubleshooters have a lot of experience behind them. As with a lot of folks on this board, just hearing the symptoms of the problem causes us to think of potential causes. There aren't too many books I can think of that will make up for experience.
All troubleshooting techniques involve breaking a problem down into smaller parts and verifying which parts work and which don't. All engines require compression, ignition (at the right time) , air and fuel to run. So verifying each of these 4 major items is usually steps one through four.
Having a good reference manual is probably the best you can do for yourself. Also, it's good to have the right tools, like a timing light, compression tester, and wrenches. A digital volt ohm meter is useful as well. If you have these things, then consult the manual and use the tools to verify the basics. Often times this will lead you down the right path. The troubleshooting trees in some of the better service manuals are fairly helpful.
As 400bird said, this site is a priceless. There are tons of arcticles in the archives you can do a keyword search on. And the folks that hang out here have a sick fascination with helping other folks solve problems.
dnult is offline
post #4 of 6 (permalink) Old Aug 25th, 06, 06:24 PM Thread Starter
shane mattix
Sounds good to me....
smattix is offline
post #5 of 6 (permalink) Old Sep 17th, 06, 08:05 PM
Thomas
4 stroke: Suck, squeeze, bang, blow.
And like he said, you're either not getting gas or not getting spark.
After that the possibilities are endless.
tubergonz is offline
post #6 of 6 (permalink) Old Sep 17th, 06, 08:23 PM
CDJr
Theres a lotta good books, some engine-specific, some general. Just about any by David Vizard will be worth the read, and he has several...very informative. Go to Amazon and search for his titles.
CDJr is offline
1967 replacement owner plan book & protecto plate nikkisdad Tag Team 8 May 15th, 06 10:50 AM
The Definitive 1969 Camaro Z28/SS396 Fact Book Gambitt Restoration Corner 14 Apr 10th, 06 06:43 PM
1969 Camaro Reference Book BlackoutSteve Restoration Corner 11 Feb 18th, 06 08:38 PM
383 build. Suggestions welcome... MarkM Performance 26 Jun 17th, 05 01:41 AM
Pro-Touring book by Tony Huntimer davidpozzi Brakes, Suspension & Steering 9 Jul 11th, 04 11:43 AM
