68 camaro dash lights - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 25th, 06, 10:32 AM Thread Starter
How do I get the lights in my car to work? What do I have to do? I am talking about the lights behind the speedometer etc. Please help!
dreamweaver1984 is offline
post #2 of 5 (permalink) Old Aug 25th, 06, 11:00 AM
Re: 68 camaro dash lights
have you tried turning on the headlights or parking lights, then twisting the know as far counter clockwise as it will go?
Have you checked the LPS fuse?
Does the light in the stock radio, heater controler, or console automatic trans shift quadrant light up?
post #3 of 5 (permalink) Old Aug 26th, 06, 02:31 PM
William
William's Avatar
It sounds like the ground wire was missed when the instrument cluster was installed. No ground, no lights. It is a loop of wire on the back of the cluster that is supposed to engage the top center cluster retaining screw. Loosen the cluster and have a look. You may have to remove the speedo cable.
William
CRG
William is offline
post #4 of 5 (permalink) Old Aug 26th, 06, 04:09 PM
This same ground also attaches at the high beam indicator.
Once apon a time, I put this assembly together in the wrong order. The red lens has to go on first. If it's installed between any of the metal peices it will break the ground.
Note that the dash cluster not being grounded will play hell with your turn signals and your fuel guage as well as the illuminations bulbs, but won't affect the idiot lights.
post #5 of 5 (permalink) Old Aug 27th, 06, 08:47 AM
Also, there aren't many lights back there to begin with and they burn out easy. So you may simply have multiple burned out bulbs..........
Dave F. in Rhode Island
Chevy-SS is offline
Changing light bulbs in dash 68 Coupe Stewie Electrical & Wiring 7 Aug 3rd, 06 05:57 AM
tail lights arent staying on 1977 camaro chevy77 Camaro Tech 0 Apr 19th, 06 03:07 PM
DIY Network 1968 Camaro Restoration Show Brentmc Bench Racing 2 Mar 14th, 06 09:41 AM
Turn Signal Dash Lights - What now? HELP! chedderboy Electrical & Wiring 9 Dec 26th, 05 07:59 PM
Dash lights?? bigs5150 Electrical & Wiring 1 Nov 11th, 05 04:34 PM
