No power steering????????? - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 25th, 06, 10:58 AM Thread Starter
II just purchased this killer 68 Camaro w/ a new 396 big block, alum head, serpentine-belt driven beast 530 hp. @ the flywheel. The motor was done up with no expense spared (buy the previous owner--even better). There are billet Alum pulleys throughout the front of this engine. All components of this engine are new (no rebuilds)
The problem, I am getting no power steering at all. The "original" steering gear box is in place and shows no signs of leakage, no visual defects noted. The high pressure hose and low pressure hoses are new and installed correctly on the gear box side and the pump connection side. Yes, there is fluid in the pump-which is also new. I did mention this engine is serpentine belt driven, so the belt is on the correct side of the pump's pulley (right-side w/ clockwise rotation). However, the billet pulley is larger then the "standard" pulley, it's currently approx eight inch diameter. The belt is rotating and shows no slipping. Neither the pump nor the gear box is making any abnormal noise(s).
Question, Note, I did not install this pump, is there such a thing as the possibility of the pump being the wrong pump--different flow/rotation requirement? Can the pulley be too large and causing the improper "flow" requirements? Any ideas? This is strange.
indpthwill is offline
post #2 of 5 (permalink) Old Aug 25th, 06, 11:58 AM
Re: No power steering?????????
If the pulley is too large, you may find that you lack power assist at idle or while parking. You will regain power assist as your engine rpms increase. This does not sound like your problem.
It sounds as if you have a pump problem. Possibly rotating in the wrong direction. Unfortunately, I do not have information on identifying a reverse rotation pump.
JIML82 is offline
post #3 of 5 (permalink) Old Aug 25th, 06, 06:47 PM
Yes! it is possible that the pump is rotating the wrong direction. There are pumps for both rotations, Serpentine running on the Vees, or running on the flat side of the belt.
It is not easy to tell which pump is which. The best I can say is disconnect the pressure line and turn the pump by hand and see if it is pumping out the line.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #4 of 5 (permalink) Old Aug 27th, 06, 08:49 AM
Yeah, I'll bet pump is rotating in wrong direction...........
Dave F. in Rhode Island
Chevy-SS is offline
post #5 of 5 (permalink) Old Aug 27th, 06, 09:37 AM Thread Starter
I replaced the pump, we have power steering.
The pump I had taken off and replaced, is brand new, however, I think the previous owner may have operated the pump dry--for long periods of time. Maybe he burned it up????????????
Thanks for the infor.
Power Steering And Header Clearence JAKER110 Brakes, Suspension & Steering 8 Jul 20th, 05 04:00 PM
Power steering problem after front end rebuild BC Brakes, Suspension & Steering 4 Jul 7th, 05 09:15 PM
Twitchy 3rd gen power steering box Midnight68 Brakes, Suspension & Steering 7 May 26th, 05 05:31 PM
Power steering problems!!! dustys Troubleshooting 5 Mar 10th, 00 11:26 AM
