Engine dies when letting off throttle - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 31st, 06, 07:59 PM Thread Starter
Jeff
Hey all,I have a 68 with a 327 and a holley 650 double pumper.It has been running fine while I have been working on it in the driveway.Finnally put it on the road,ran well for first 10 mile trip,took it for another trip right after that car runs well,it has a turbo 350 I was doing 35mph down the road took my foot off the gas and the car died? pulled over car started right back up,did this a couple times till i coasted to a gas station thought i was about out of gas.Put in 10 gallons car did it again.There was a lot of pressure out gas cap but that seems fine from what I have read.I have a manual fuel pump,I thought that when they go bad its all at once?I know my float bowls are a little high would they do this?I had the tank out and it did not seem there was debris in it,plus the car starts again.One more little tid bit the last time when I went to start it nothing not even a click I am thinkin that is because my starter got hot?It seemed to be running about 180*?
SC42 is offline
post #2 of 4 (permalink) Old Aug 31st, 06, 09:53 PM
Call me Jim
Send a message via AIM to brightblue87iroc
Re: Engine dies when letting off throttle
Sounds as simple as the floats too high. You can't set a Holley by the dang bowl sight plugs--if that's that you did SC--because they will ALWAYS be too high. Try turning the float needles 3/4 to 1-1/4 turns to the right to lower the float levels. This may cure your problem.
brightblue87iroc is offline
post #3 of 4 (permalink) Old Sep 2nd, 06, 05:54 AM
IMO, you have a few possibilities here. Could be:
1) carb needs rebuilding
2) clogged fuel filter
3) vacuum leak somewhere
4) rubber fuel hose (front or rear) cracked and allowing air
5) fuel pump on its' way out
6) clogged fuel tank pickup screen
Should be a relatively easy fix. Please post results...........
Dave F. in Rhode Island
Chevy-SS is offline
post #4 of 4 (permalink) Old Sep 2nd, 06, 09:19 AM Thread Starter
Jeff
Readjusted floats...but I am sure the problem was a clogged fuel filter! Thanks for the help
SC42 is offline
Small jets but still seems rich. camaro_fever68 Performance 10 May 24th, 06 04:46 AM
Engine dies when I hit the brakes! Mister G Engine 5 Mar 19th, 06 10:44 PM
My 502 is driving me mad !! Engine Gurus', Please Help Me. paul1969 Performance 25 Dec 4th, 05 09:55 PM
engine builder's code of ethics?? / big block oil pressure ?? caribbean camaro Engine 4 Jul 9th, 03 03:05 PM
Engine dies once operating temp is reached. Raven87 Troubleshooting 8 Mar 4th, 01 07:50 PM
