noise - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 6th, 06, 10:08 AM Thread Starter
noise
I have a noise that I here when I drive the car. The engine is loud. Its a 67 with a BBC.
When I accelerate and then release the accelerator the noise happens consistently. Its a tinny noise that you have to listen for. It is glaring to me but I had to point it out to others not used to hearing my car.
I had a tranny guy ride with me, he built this TH400. It has less than 1500 miles on it.
He didn't think it was tranny because he said it would happen more consistently than just after I get off the gas. He also said it would most probably be louder if it were tranny. He was listening for grinding or clunking.
This is a tinny whisper on deceleration.
It doesn't happen when revving it in neutral or park. It doesn't happen or at least I can't hear it when accelerating. The engine is noisy so I might not be able to hear it when accelerating.
mkpatrick is offline
post #2 of 7 (permalink) Old Sep 6th, 06, 11:12 AM
Frank
Send a message via MSN to jet_car2000
Re: noise
Does it sound like its in the engine bay or under the car?? might be a vacum leak or a small exhaust leak,,, really hard to say without hearing it.
Frank
jet_car2000 is offline
post #3 of 7 (permalink) Old Sep 6th, 06, 11:23 AM Thread Starter
Re: noise
Frank
It does sound like its underneath, like the tranny. That's why I had the tranny guy listen. But after listening again, we both seemed to think it was coming from forward of the tranny.
If it were exhaust, wouldn't that give some popping sounds? This sounds tinny. As though something made of thin metal is turning or rubbing on something.
post #4 of 7 (permalink) Old Sep 6th, 06, 12:06 PM
Re: noise
I HAVE ONE JUST LIKE THAT!!!
Long shot, I know... but the dust shield on the front of the pinion, behind the yoke, is loose, and makes EXACTLY that noise under EXACTLY those conditions. Been like that for years, Freddy said don't worry bout it, so I don't.
long shot but don't hurt to peek!
post #5 of 7 (permalink) Old Sep 6th, 06, 01:23 PM Thread Starter
Re: noise
The yoke is the U-joint right? Or is this dust shield more near the differential?
Do you think there would be some rubbing signs present?
Also, does this noise happen for you when you decelerate or when you are moving at any time?
Thanks,
post #6 of 7 (permalink) Old Sep 6th, 06, 01:32 PM
Re: noise
the dust shoild is a metal ring behind the yoke on the front of the axle. It rotates with the pinion, and "should" be tight...
Mine has come off whatever secures it and is just rattling around there.... like a big washer on a little bolt.
I hear a very very slight tinkling all the time (couldn't hear that if the mufflers were louder) and it's louder when my speed is changing (tho I can't hear it over the pipes when accellerating) loudest when decelerating.
worth checking anyway.
post #7 of 7 (permalink) Old Sep 7th, 06, 07:32 AM Thread Starter
Re: noise
Well, I jacked up the car and after waiting for my wife to come home, I slid under there. (She and I agreed that if I'm home alone, it wouldn't be a good idea to get under a jacked up car just in case something failed, she doesn't want to be the one to find my corpse under a car. This would cause her to have to requisition a whole new husband and that is a hassle!)
This dust cover seems to be intact. I did however, notice that the mufflers and pipes are closer to the drive line than I once thought. Then, I noticed that there were these lines in the dirt that has adhered to the drive line. Almost like those pipes have been rubbing on the drive line. They are very close. I don't know why the muffler shop put them that close. Maybe its time to take them back there and have them move them a few more inches away.
clutch noise when engaging larrys68 Troubleshooting 3 Apr 6th, 05 07:48 AM
Rattling noise when I put the trans in gear?? Joel Koontz Transmission & Driveline 3 Jun 9th, 03 01:40 AM
strange noise Marc Engine 2 May 11th, 03 10:13 AM
Engine makes clicking noise Marc Troubleshooting 17 May 13th, 02 10:31 AM
What is this noise? PERKS67-396 Troubleshooting 4 Jun 27th, 01 03:20 PM
