Engine shuts off when put in gear - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 10th, 06, 09:43 AM Thread Starter
I need some help, I have an 88 Camaro Iroc Z28 305 automatic with a 2 barrel. It is a stock engine and is all of a sudden shutting off when you put it in gear. We have replaced the following plugs, wires, dist cap, fuel filter, and gas. We also replaced some sensors. The engine starts fine but when you go to drive or reverse it shuts off. It does not lunge forward it just cuts off. Any ideas what I can do to fix this.
Maria
Maria is offline
post #2 of 4 (permalink) Old Sep 11th, 06, 03:39 PM
Send a message via MSN to kausboy
Re: Engine shuts off when put in gear
I am guessing it is an automatic trans and that your lock up converter is stuck.
kausboy is offline
post #3 of 4 (permalink) Old Sep 11th, 06, 04:25 PM
Harry
dawg's Avatar
or it could be the modulator vacum line is off and huge vacum leak will be more apparent under load.
434 stroker
US Navy retired
dawg is offline
post #4 of 4 (permalink) Old Sep 17th, 06, 07:30 PM
Thomas
Stuck Torque Converter Clutch. I had a friggin Corsica do that the day I bought it.
IF that is the problem, the only thing I can suggest is to disconnect the TCC wire from the transmission. The car will probably die a few more times before the clutch dissengages. Once it finally lets go, forget about it and the fact that your highway mpg went down (until you feel like getting it rebuilt).
tubergonz is offline
Lifting and Installing Engine sdtsdt Engine 6 Apr 30th, 10 06:00 PM
What engine is this inside of my 67 Camaro?? camaro_town Tag Team 3 Apr 23rd, 04 05:14 PM
Oil Pump Info High Volume Myths & Fables Set Straight camaroman7d Engine 21 Apr 16th, 04 02:54 PM
TH350 Drive Gear? camaro-novice Transmission & Driveline 22 Jan 25th, 04 05:51 AM
engine builder's code of ethics?? / big block oil pressure ?? caribbean camaro Engine 4 Jul 9th, 03 03:05 PM
