about to get new camaro - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 15th, 06, 07:07 PM Thread Starter
The only problem is has and it's not a major one but the Engine service light comes on when my dad presses off the brake. Sometimes it'll stay on and go away but eventually it'll come on. He pay over $800 to try to get it fixed but it isn't. He had them replace the EGR Valve and the computer but it's doing the same thing as before. Anyone know how to get rid of this problem. Is it the oxygen sensor going bad?
It's a 1994 camaro with almost 200k miles. But the engine still runs great.
amb7247 is offline
post #2 of 9 (permalink) Old Sep 15th, 06, 07:55 PM
DjD
DjD's Avatar
Re: about to get new camaro
Replace the gas cap if you haven't, it's a common chk engine light trigger as it's part of the smog stuff on that car... It will take several cycles of the key to clear the code but it will go away if that is the problem.
...Dennis
DjD is offline
post #3 of 9 (permalink) Old Sep 15th, 06, 08:03 PM
Craig
Brackneyc's Avatar
If the check engine light is on, then there is a code that can be pulled from the computer. Don't spend any more money until you have had it diagnosed. Take it to Autozone and have them pull the codes. It is free, and could potentially save you tons of cash. It could be an oxygen sensor, but if you spent 800.00 trying to get the light to go off, and a mechanic didn't atleast suggest the O2 sensor, then he is not a very good mechanic, imo. Could be a Mass Air Flow sensor, MAPP sensor, throttle position sensor, knock sensor, etc... The code could provide the answer.
Craig
Now you will see that evil will triumph, because good is dumb.
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Brackneyc is offline
post #4 of 9 (permalink) Old Sep 15th, 06, 10:03 PM Thread Starter
I'll have my dad do that tomorrow when he fixes teh drain plug. The bastards at the auto shop stripped the threads on teh oil pan.
I would assume that the camaro manual book has all the codes? I am not sure.
amb7247 is offline
post #5 of 9 (permalink) Old Sep 16th, 06, 06:12 AM
Christropher
Easy on the name calling. Everyone makes mistakes!
Christropher
...in pieces still.
clwilcox33 is offline
post #6 of 9 (permalink) Old Sep 16th, 06, 08:09 AM Thread Starter
Are the codes at http://autorepair.about.com/library/...l-dtcs-51a.htm accurate. And autozone can check this for free. Would stink if he gets to the store and its not free and the light isn't on when he tries to check it. If those codes are not correct can you point me to a site that has the correct codes?
amb7247 is offline
post #7 of 9 (permalink) Old Sep 16th, 06, 12:36 PM
Craig
Brackneyc's Avatar
The service is free. I have worked there for four years. I guarantee the service is free. The check engine light must be on at the time however. If the light is off, no codes will show up. If you go there and the light is off, have the guy show you how to check the light yourself. You can do this with a little key (we give them out for free) that you plug into the OBD port.
Craig
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
post #8 of 9 (permalink) Old Sep 16th, 06, 10:56 PM Thread Starter
does discount auto parts do the same thing. I have like 3 stores alone here in town.
amb7247 is offline
post #9 of 9 (permalink) Old Sep 17th, 06, 01:21 AM Thread Starter
One more question. Is there one or two oxygen senors required for a '94 camaro. And if there are two of them which I think there are how and where to they install? Is it tough to do?
amb7247 is offline
DIY Network 1968 Camaro Restoration Show Brentmc Bench Racing 2 Mar 14th, 06 09:41 AM
69 Camaro Trike edd Gordon Bench Racing 0 Mar 11th, 06 11:53 AM
Vintage Camaro [email protected] Camaro Nationals shaugs Bench Racing 0 Nov 23rd, 05 07:36 AM
CAMARO IS BACK IN 2007!!!!!!!!!!!!!!!!!!!!!!!!! dawg Bench Racing 32 Apr 24th, 05 07:27 PM
Finding the good 69 Camaro. hemi.42 Tag Team 2 Jul 6th, 04 06:40 AM
