95 Camaro won't start - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 24th, 06, 09:43 AM Thread Starter
working on a 1995 Camaro with 3.4 liter SFI, does have the security system, engine will turn over but won't start, checked spark..its has good spark, found no fuel pressure, no power running to fuel pump, but fuel pump will run if hook 12 volts to it, replaced the realy to fuel pump under dash, still no power to pump...HELP!!!!!!!!
shadetree_mechanic is offline
post #2 of 5 (permalink) Old Sep 24th, 06, 01:27 PM
Re: 95 Camaro won't start
There might be a fuel cut off switch or kill switch somewhere.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 5 (permalink) Old Sep 24th, 06, 07:44 PM Thread Starter
Thumbs down Re: 95 Camaro won't start
Thanks dave!!!
i was thinking more of something to do with the key or the security system, we did look for a kill switch , but didn't locate, any clues were it maybe located?? how do you reset the security system??? we tried to hook up a code computer up to service port and could not read the computer?????
post #4 of 5 (permalink) Old Sep 24th, 06, 08:19 PM
I can only guess where it might be located. Only the installer or the previous owner would know. If I were to guess a good place would be under the dash or near the driver's seat. Have you tried tracing the wires from the fuel pump to the fuse box? Also have you checked the fuse for the pump?
I'm not sure how to reset the security system. You might want to disconnect the battery for awhile and see if that has an effect.
post #5 of 5 (permalink) Old Sep 24th, 06, 10:37 PM Thread Starter
fuse is good, i did read in the forums of possible fuse by battery for fuel pump????will look for that in the morning, also read something about just sticking the door key into door lock and locking-unlock can reset security, will try the battery cable though, ill let ya know more tomarrow what we found..thanks again!!!
yes, we did trace the wire to the fuel pump, we can jump it at the relay under dash and it works that way
'67 Camaro no start BW67 Electrical & Wiring 10 Feb 26th, 06 09:22 AM
68 camaro won't start!!! jheabs Troubleshooting 4 Feb 19th, 06 07:20 PM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
68 Camaro refuses to start rodsters Troubleshooting 1 Jun 2nd, 02 12:08 PM
1987 camaro...Wont start?? lazisgod Engine 2 Oct 23rd, 01 04:16 PM
