problem - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 24th, 06, 12:41 PM Thread Starter
problem
i have 85 iroc z 305tpi idles ok when i step on ths gas wants to cut off if i let off stays running any help is cool thanks
louis manco is offline
post #2 of 7 (permalink) Old Sep 24th, 06, 01:21 PM
Re: problem
Does the check engine light come on when the engine starts to cut out?
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 7 (permalink) Old Sep 24th, 06, 01:25 PM Thread Starter
Re: problem
no
post #4 of 7 (permalink) Old Sep 24th, 06, 01:35 PM
Re: problem
You might have a fuel pump problem of a plugged fuel filter.....start there.
post #5 of 7 (permalink) Old Sep 24th, 06, 01:36 PM Thread Starter
Re: problem
this is a couple of things iv done so far since i baught it. new fule pump and sending unit new exust new fuel filter also new radiator plugs wires distibuter.
it is the first 1/4 of pedle once i pass 1/4 it sounds like it is getting to much fuel when i back off right back to good idel
post #6 of 7 (permalink) Old Sep 24th, 06, 01:41 PM Thread Starter
Re: problem
when i hold it past 1/4 it stays runnig but bogs down
post #7 of 7 (permalink) Old Sep 24th, 06, 06:59 PM
Re: problem
Get your throttle position sensor checked.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
In Need Of Major Help!! Please!! Justgotacamaro Engine 31 Mar 6th, 07 05:22 AM
Air Conditioning Problem Mark C Heating & Cooling 21 Jul 17th, 05 10:16 AM
Holley problem SICKT9 Engine 5 Jun 11th, 05 02:21 PM
BBC engine Vacume problem 68and69ss Troubleshooting 4 Jun 1st, 05 05:49 AM
arcing problem camaro-69ss Electrical & Wiring 2 Apr 6th, 05 08:59 PM
