LT1 Swap Computer Issue - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 30th, 06, 08:00 AM Thread Starter
Have a 67 RS/SS Convertible with a 94 LT1 donor engine/computer. Following are the known mods/specs (I'm sure some are irrelevant for this question but just in case). The computer is not communication with any programming tool. On the OBDII Harness (Painless Harness) there are the 12volt and two 5volt reference lines present.
Symptoms: Idle all over the board - mostly 2500 rpm but drops down to 800rpm occasionally, headers are running extremely hot (rockers have just been adjusted), occasionally severe hesitation.
I am trying to figure out what the correct steps to troubleshoot this system would be. Also, assuming the computer is bad, what system (cost effective as I have blown my wad on the rest of the car!) would you recommend?
Donor Car: 94 Camaro SS VIN# Unknown, Codes on the computer: 86BMJRK1414575ZL, BMJR, 16210011
Vortech Blower
Cam: Lt4 Hotcam GM Part #24502586
Heads: LT1 Ported to 2.05 intake & 1.67 exhaust
Comp Springs w/ Titanium Caps
Pistons: TRW Dished Blower Pistons 9:1 compression
Stock rods & crank
Engine bored .030 over
2 Bolt main
Fuel system: Rock Valley fuel pump pressure 45 psi
Injectors: SVO 36lb injectors
Clutch: 11" centerforce
Rear Axle: Strange Ford 9" rear posi 4:11 gears
Roller rocker tips 1.6
Vortech Supercharger
Wilwood Braking system 12.1" plated/drilled/slotted rotors front and back w/ 4 piston calipers and Wilwood main cylinder
Power Steering
Power Windows
Airride Technologies Rear Suspension
Oversized Aluminum Radiator
Flex-a-Lite Dual Cooling fans
RockValley Stainless Steel Gas Tank
Autometer Phantom Gauges
Martz Drag Front End 3" drop spindle coil overs
Box Reinforced Frame
Detroit Speed Subframe Connectors
Painless wiring harness (engine and car)
Magnaflow 3" dual exhaust
Ceramic Coated Headers
StompS is offline
post #2 of 5 (permalink) Old Oct 12th, 06, 12:22 PM
Matt
Re: LT1 Swap Computer Issue
Stomps, I am not a computer gearhead but have some lt1 experience from my 95 ss impala. Here are some things to look at-
You have an OBD 1 car (pre 1996) and an OBD 2 harness-cold be the whole problem.
Also all of the mods you have on that engine will definately require a reprogram of the computer. Bryan Herter of PCMS for less does a lot of work for guys on the impala ss forum and can help you out at a reasonable price. Also tons of info on the forum about modded lt1s.
http://impalassforum.com/noncgi/ultimatebb.php
Good Luck
Camuchi is offline
post #3 of 5 (permalink) Old Oct 12th, 06, 02:55 PM Thread Starter
Funny you should recommend Bryan, as I called him an he did, in fact, program my computer. Everything is OK now except that I am running about 1100RPM at idle and hesitating and some backfiring when decelerating and then giving a little gas. Laso, I am burning about twice as much fuel as I should be and my Air/Fuel guage is still all over the board. I just cleaned my sensor in my blower tube but it did not make a change. I have been looking for a vacuum leak but am coming up short...
StompS
Portland, Oregon
67 RS/SS Vert w/Supercharged 94 LT1
StompS is offline
post #4 of 5 (permalink) Old Oct 13th, 06, 05:51 PM
Jerry
You may want to try "Chevythunder.com". They have some great info and links for TPI troubleshooting.
Jerry
Hot 67 is offline
post #5 of 5 (permalink) Old Oct 13th, 06, 06:07 PM
Jerry
You may want to check ouy "Chevythunder.com" , they have lots of good info and links for troubleshooting TPI.
Jerry
Hot 67 is offline
Help with leaf spring swap gusher Brakes, Suspension & Steering 8 Dec 28th, 06 09:39 AM
lt1 swap TheGr8Schlotzky Performance 1 Jun 10th, 06 08:37 AM
LT1 motor swap Seneca SS Engine 0 Mar 30th, 06 05:09 PM
Drive line vibrations - big block swap 69OrangeTwist Engine 1 Mar 28th, 06 04:16 PM
LT1 Computer programming Tokala Bench Racing 3 Apr 13th, 05 04:34 PM
